LG 50PK790 No Image No Sound
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50PK790 No Image No Sound
    Phosphor is not a gas and it does not act like one for a start, Xenon, neon, argon etc are in the panel they are gases. No way in hell do they overload or overheat either thats Bs you made up. The only way a Pdp can fail is if its cracked or the Panel electrodes short which almost never happens.
    Also the other stuff about X/X and Ysus boards you said doesn't make sense Im not even going to bother justifying that. Dont pretend to be a Pro if you know nothing, you will be shown up very fast on here.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by RavenHerald
      I hadn't even considered that it would be the solder, just presumed it would be one of the components! Thank you I will see if I can get it working, otherwise will be in touch if you did want to take it.
      Awesome keep us updated
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Originally posted by charis
        You are trash!
        i try to talk simple all this gas inside a plasma is acting like a Phosphore.
        In the instustry is a common language from the past every technician know this.
        I do this for a living if you guys thinks you smart i said all the common problems on lg plasma in the above post.
        Is the greek back? His brother in law perhaps? Another fucktard up for banning,that's for sure. Stop right there greek,your not smart,not at all.
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Martino I love the way you put things
          • RavenHerald
            • May 2016
            • 11
            • England
            Tried the oven trick and it works completely fine -all fixed and thank you so so much!
            I really appreciate the help, so glad it was fixable and now I can continue wandering the wastelands in Fallout!
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Awesomeness, my advise would be add a small fan over the Cpu heatsink. Should keep it chugging a little longer
              • RavenHerald
                • May 2016
                • 11
                • England
                #27
                Thank you I will get that sorted as well, so happy it's alive and would like to keep it that way for as long as possible.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Hopefully, too bad Lg cheeped out on the Cpu cooling could of lasted longer
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    #29
                    All you Plasma sets in Greece....
                    Be Afraid--Very afraid!-- There's a madcap wannabe 'tech' in your country!
                    TELEFIX
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • domix
                      Sony KD - 65XF9005 - No image, sound OK
                      by domix
                      at tv KD - 65XF9005 i have a problem.
                      Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                      is this a common problem for this tv?
                      i attached pictures of inside. Supply board looks okey, no blowed caps....
                      07-21-2025, 06:37 AM
                    • Kartowl
                      philips 47pfl6158k/12 image faded away, sound still coming from TV
                      by Kartowl
                      Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                      04-23-2024, 12:57 AM
                    • wolf1976
                      samsung ue40d6100 has no backlight no sound and image
                      by wolf1976
                      hi to all
                      on the above model of samsung i have the faults i have told already on the title
                      iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                      any idea from someone what can i measure so i can find the problem ?
                      the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                      11-17-2024, 01:02 PM
                    • howardc64
                      LG 43UK6500AUA no LCD image, backlight and sound okay
                      by howardc64
                      Similar to another LG UK series here
                      https://www.badcaps.net/forum/showthread.php?t=93943
                      Have backlight and sound. no LCD image.
                      • main board has integrated T-Con
                      • main board T-Con has LCD DCDC/PMIC RT6950GQW QFN68 package. Richtek chip. Can't find datasheet. Chip generates VADD (10.44V), VGH (~28V), VGL (~-14.5V)
                      • RT6950 pin 18-19 (clockwise) appeared to be bridged. Unlikely from my probing, looks like ball squeezage so it probably got hot
                      • Cleaned up bridging. Pin 17 is VGL (-14V) Pin 20 is VGH (28V). Pin 18 (I think 19 too) jumps between VGL and VGH voltage
                      03-12-2023, 01:04 PM
