Samsung PN50B450B1D showing evenly spaced vertical lines
  • rifeman2000
    • May 2016
    • 9
    My TV started showing evenly spaced, vertical lines across the entire width of the display. Just eyeballing it, I would say the lines are about 1 inch apart and 1 pixel wide. They are always in the same place, appear stationary, and appear over the top of the TV menu. They also appear on all inputs. When looked at against a lighter colored background, they alternate between a subtle green and subtle red.
    I've referenced a post from "capkid" that point to the logic control board. I've taken a picture of the TV with the back off and a zoomed in picture of what I think is the logic control board. Any help would be awesome! Thanks!
    -Chad
  • tw2005
    • Oct 2011
    • 6458
    Re: Samsung PN50B450B1D showing evenly spaced vertical lines
    -Chad
    I'd be thinking along the same line it sounds like it.
    LJ92-01617A
    There is a procedure to isolate the main board, jumper the logic ctrl bd test pattern generator, I think the PSU also needs to be jumpered to turn on at plugin.
    Was there any mention of that in the other thread? If the lines were still there running just off the Logic board that would confirm that's the issue.
    • tw2005
      • Oct 2011
      • 6458
      something like this, you don't have to remove the main board, just need to disconnect the power and LVDS cables.
      • rifeman2000
        • May 2016
        • 9
        tw2005, here is the full post I was referring to (from capkid):
        Originally posted by capkid
        I was helping a guy on YouTube with one of these TVs - he has evenly spaced vertical lines. The guy just about drove me nuts:
        Me: Since the lines appear to be evenly spaced, I'd say that you have a logic control board problem. I'd try re-seating the connectors or cleaning the contacts with electronic contact cleaner first. If that doesn't work, I'd replace the logic control board; it's the small board that usually sits somewhere near the center of the panel.
        TV Owner: Where is the logic control panel? And the connector
        Me: It's the logic control BOARD, not panel. I explained in my previous comment that it's a small board on the back of the plasma panel. You'll see the connectors going to that board. Again, either the connectors need to be cleaned or the board most likely needs to be replaced.
        TV Owner: I did research on Google n alot of people having the same problem with this tv. They said it could be the y-main board r plasma panel need to be replaced
        Me: What's the model number of the TV?
        TV Owner: PN50B450B1D
        Me: Ok, I've worked on several similar Samsungs. Other people may have just a few vertical lines on one side of the panel, and that's normally a bad panel. In your case, you have evenly spaced lines, which points to a processing issue. There are more involved tests you can do, but first try bringing up the TV's menu to see if the lines are in front of the menu or behind it. Do the lines move or are they always in the same spots? I highly doubt you have a panel or Y-main problem.
        TV Owner: So what problems do you think I'm having if its not a panel r y-main board problem
        Me: I'm sorry, but you're obviously not listening to my advice. You cannot diagnose an issue without testing it, and you aren't posting any results of tests I've suggested you perform. Please reread my comments. I'd replace the logic control board if the lines are stationary. Hopefully, you can solve your problem. I need to move on. Here's how to identify parts: watch?v=R1jmj_foId0
        I've also attached a picture of the image produced on the screen. The lighter colored lines are more apparent, but if you look closely, you'll see the darker (reddish) lines in between each set of lighter colored lines.
        • rifeman2000
          • May 2016
          • 9
          I'll give this a try! As an aside, about how long does it take the capacitors to discharge so I don't end up frying myself?
          • rifeman2000
            • May 2016
            • 9
            I followed the instructions in the powerpoint. The menus and options on my TV were different then the powerpoint. Attached is what I found.
            Control -> PDP Option -> and no way to get to the test pattern.
            Going back to Control -> Test Pattern -> I'm able to get either the Master of LOGIC test patterns. The lines appear on both test patterns (I included one from the LOGIC pattern test. The horizontal bars are just distortion from the camera. It actually appears as a solid grey screen with the red and green lines as previously discussed.)
            Since lines are present, does the LOGIC test show there is a problem with the logic control board, or is more troubleshooting required; ie, disconnect power and LVDS cables?
            Thanks for the help so far! This is a blast!
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              I'd say logic board BGA chip letting go. Did you try heating the logic board with a hairdryer to see if it chances?
              Proud owner of dozens of broken TV's and many,many,many boards.
              Our website and passion:http://hollenhundshepherds.com/
              • rifeman2000
                • May 2016
                • 9
                In case it wasn't clear, the section of my message quoted above should read "I'm able to get either the Master OR LOGIC test patterns.
                Martino, I'll give what you said a try!
                • rifeman2000
                  • May 2016
                  • 9
                  ***FIXED!!*** It was the logic control board...a $15 part! Thanks for all the help.
                  Is there any way to edit the thread title so that when people are scrolling through they can quickly see what the fix was?
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    yay! good news and cheap fix
                    • mmartell
                      • Oct 2013
                      • 3189
                      ***FIXED!!*** Is there any way to edit the thread title so that when people are scrolling through they can quickly see what the fix was?
                      Nope. There is an old thread requesting this feature but Topper decided against it.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Awesome, I have the same Tv im repairing and I have added heatsinks to the Bga chips on the control as they get hot. You might also want to resolder every Igbt on the Xsus which can help prevent future issues.
                        • Andriod
                          LG 47LN577 with black fading horizontal evenly spaced lines
                          by Andriod
                          So, I have searched the internet for long, high and low and ended up here.
                          As the title suggests; there are static repeating black-ish horizontal lines that start from the left and fades away at around 65% toward the right, meaning its length is more than half the screen. The lines are from top to bottom evenly spaced. I can see the lines on the test image, and on chromecast input.
                          This is my first time investigating TV errors at this level, and my initial googling led me to believe it was the T-CON board, considering that it has a left-ish problem. But googling even...
                          12-30-2020, 03:38 PM
                        • 205rogers
                          by 205rogers
                          When I first turn my TV on, it works fine for a few minutes and then the attached vertical lines show up across the screen. If i turn it off and back on same thing, works for a few minutes then the lines come back.
                          I have read other posts about the T-con PWB. Not sure if thats the problem with mine or not. Hoping to get some advice. Thanks...
                          10-06-2018, 08:35 AM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • Stanley1843
                          by Stanley1843
                          06-29-2024, 11:54 AM
                        • jeyoung12
                          Samsung QN50Q60t lines on screen
                          by jeyoung12
                          Hi all
                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                          So....i don't know what end of the C ribbon to work with...
                          02-26-2024, 10:38 AM
