AS15F replacement which fluxes?
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Good morning, I have 3 lcd's with milky or white pictures, with the AS15f chip to hot to touch. I have seen two clips on you tube where the chips are changed using a hand held soldering iron. (ouch!)
    In the one clip, a lot of clear looking fluid is squirted on during the removal process. Is this just cleaning, or cooling as well? What fluid would be recommended?
    The second clip looks like a concoction in a syringe? Could I maybe have a local chemist mix up something?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: AS15F replacement which fluxes?
    The make of flux does tend to be a personal choice. Some fluxes appear not to boil away too quickly or leave a heavy residue behind. Some also come in a syringe which can make it easier to spread the flux only where you want it.
    Isopropyl or something similar is sprayed on afterwards to remove the flux residue prior to fitting the new device. Fresh flux and fresh solder is then used at this stage.
    Suggest you practice on an old board.
    • Grunder
      • Jan 2016
      • 323
      • south africa
      Thanks Dick, have plenty old boards with same/similar IC to practice on. Will google fluxes and also ask my delivery guy what the other gents are using.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        There is an added difficulty in removing the AS15x chips if the base of the IC is soldered onto the copper below it. Requires more heat to dislodge it while being careful not to overheat and damage the tracks. Something I am familiar with doing myself.
        • diif
          • Feb 2014
          • 6978
          • England
          I've used Chipquick to help remove them in tje past, although I prefer hot air now.
          I use genuine Amtech 559. Flux with a needle to dispense it accurately.
          Not the cheapest but doesn't dissapear at the first sign of heat.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            The hot air gun is definately a plus but do not put the airflow up so high that it blows the very small smd's off their solder pads. I've done that too.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Nah--No problem!
              Cut the pins off chip with Stanley-knife then remove them with solder and iron.
              Ping off chip with blade under edge, simple, easy quick.
              clean up board, coat with home-made flux, on with new chip drag-soldered.
              All done in 10 mins, and no hot-air in sight.
              TELEFIX
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Excellent suggestion Alastair E and already filed away in my head but won't pinging off the chip rip up the copper pour below it.?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Originally posted by Alastair E
                  Nah--No problem!
                  Drag-soldered
                  . Do you mean running the soldering iron tip preloaded with solder along the legs of the IC.
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Err--No, and Yes in that order!
                    Just occasionally the top will leave the chip die on the board,when you ping it off, but simple iron and solder takes care of that...
                    --Important NOT to drive the blade under the chip case, doing so could cause damage. you can get enough grip just by resting blade edge under the chip with no shoving.
                    TELEFIX
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Thanks Alastair E for an excellent hint.
                        • 31187
                        as15 does not always have copper heat-spreader under it, check the part number agains the datasheet - there are several versions.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          As15 H has a heat pad As15 F does not. Also flux does not matter any type will work, its your skill at soldering when it comes to this type of work.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Hello STJ,
                            The ones without the bases soldered to the board are not a problem. It's the one which are that I find a pain. However I do like Alastair E suggestion to remove the legs first and then I can concentrate my heat gun onto the body of the IC without worrying about damaging any tracks when lifting it off the board.
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              Aye--Even my home-made colophony concoctions....
                              TELEFIX
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Hello STJ,
                                You dont even need to do that. I just use flux and hot air for the ones with the heat pads works just as well never damaged a trace. Will be doing a youtube video soon.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  And that's what it finally comes down to. I need the practice.
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Flux, flux--And More flux--you can almost never have too much!
                                    TELEFIX
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Too true, flux is your best mate when it comes to work like this !
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        The good bit about the Colophony based type flux is you don't really have to clean it off after work-- unlike the gloopy greasy types commonly available (which I dislike), Its just like the original stuff already all over the boards anyway!
                                        Only place I do clean it off well is on Buffer-chip pins, that then get coated with ulti-meg...
                                        Easy (and cheap--I like Cheap!) to make--Take some colophony resin and dissolve in alcohol to make a strong amber coloured fluid--If you add too much colophony--it goes milky, but still works fine, but you can add a little more alc to get the clear amber back....
                                        --I use an 'e cigarette' fluid bottle to store and apply, has a short and thin spout just right for application.
                                        TELEFIX
                                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                          - No Clean Formulations
                                          - Low residue
                                          - Range of activity to deal with different component solderability
                                          - Halide free
                                          - Suitable for dispensing
                                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                          Both products are supplied in syringes or cartridges for application by dispensing....
                                          10-07-2024, 06:02 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
                                        • ezenia
                                          PS4 controller left stick potentiometer replacement issue
                                          by ezenia
                                          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                          09-30-2023, 02:19 PM
                                        • boosti45
                                          Macbook pro logic board replacement parts quesion
                                          by boosti45
                                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                          08-21-2024, 05:23 AM
