AS15F replacement which fluxes?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: AS15F replacement which fluxes?
    Looks like yet another useful tip Alastair E in making your own flux. Thanks
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Ha! I'm full of use(ful)less information!
        TELEFIX
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Sure are buddy !
            • 31196
            i use industrial water-based flux.
            btw, next time i have to fit a chip with a heat spreader, i'm going to try doing it with a tiny bit of MX4 instead of solder.
            getting them down with solder under them is a bitch - they float around and dont always align right!
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              MX4 what the thermal paste ? Also just remove all the old solder and add a drop in the middle, heat it till molten then drop the Ic on top and align.
              • Grunder
                • Jan 2016
                • 323
                • south africa
                #27
                Originally posted by Alastair E
                The good bit about the Colophony based type flux is you don't really have to clean it off after work-- unlike the gloopy greasy types commonly available (which I dislike), Its just like the original stuff already all over the boards anyway!
                Only place I do clean it off well is on Buffer-chip pins, that then get coated with ulti-meg...
                Easy (and cheap--I like Cheap!) to make--Take some colophony resin and dissolve in alcohol to make a strong amber coloured fluid--If you add too much colophony--it goes milky, but still works fine, but you can add a little more alc to get the clear amber back....
                --I use an 'e cigarette' fluid bottle to store and apply, has a short and thin spout just right for application.
                Thanks Alistair, I like the idea of cheap as well. I could make a quantity and use when needed. Just have to find some colophony resin. ( Finding the alcohol no probs!
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  I have got an AS15 to do will be showing my method in a video
                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                    - No Clean Formulations
                    - Low residue
                    - Range of activity to deal with different component solderability
                    - Halide free
                    - Suitable for dispensing
                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                    Both products are supplied in syringes or cartridges for application by dispensing....
                    10-07-2024, 06:02 AM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
                  • ezenia
                    PS4 controller left stick potentiometer replacement issue
                    by ezenia
                    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                    09-30-2023, 02:19 PM
                  • boosti45
                    Macbook pro logic board replacement parts quesion
                    by boosti45
                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                    08-21-2024, 05:23 AM
