LG 39LN5700, TV shuts off immediately after being turned on, no picture
  • pgram
    • Apr 2016
    • 37
    I was originally planning on scrapping the TV, but as I am without a descent TV at the moment and I figured I would give it another look.
    The situation: When testing voltages on the 18 pin cable connecting the power supply to the main board I accidentally shorted 2 pins. Before the TV would turn on, but there was no picture (the LED back light burnt out), after shorting the pins the TV won't even turn on (its red LED that indicated it off just flashes off then on again when the TV is power button is pressed.
    Is it still worth repairing or was I right with my original assessment to just scrap it? The TV has had steady use over a 2-4 year time period, it was left on at least 2-4 hours a day.
    Re: LG 39LN5700, TV shuts off immediately after being turned on, no picture
    Hard to help without seeing the whole back side of the TV so we can see all the boards and how they are connected together and the pictures of the connector you shorted together.
    • pgram
      • Apr 2016
      • 37
      I shorted leads on the backside of the power supply board at the 18 pin cable (that connects the power supply board to the main board). I was (stupidly) trying to check voltages at the cable connector pins on the backside of the power supply board while the TV was plugged in. I'm not entirely sure what was shorted as my view was obscured.
      These are the voltage readings I am getting now at the 18 pin cable (TV plugged in & powered off with cable to the LED backlight disconnected). This is on the topside of power board, from top to bottom:
      1: -
      2: 0.2
      3: 0.2
      4: -
      5: 23.6
      6: -
      7: 3.46
      8: 3.46
      9: 3.35
      Pictures:
      I highlighted the cable in the first picture and drew a read arrow to the area that where my multimeter lead caused the short. Let me know if you need pictures of anything else.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The connector has 18 pins. With the power supply disconnected from the main board can you put the voltages read alongside the Pin 1 -> Pin 18
        Edit
        Some of the solder joints are not looking to good.
          http://www.shopjimmy.com/catalogsear...?q=LG+39LN5700
          OK, the connector P201 on the power supply board has a chart to tell you what each pin is for, we need you to list the pin number, pin name, and the DCV reading when the TV is NOT turned on yet and AFter the power switch is activated.
          You have ODD pin that you can get access from the top of the board, the even pins can get access using small probe poking into the socket back side.
          DCV readings examples:
          Pin 1, PWR-ON = ??? V (TV OFF), ????V (TV ON)
          Pin 3, 3.5V = ??? V (TV OFF), ????V (TV ON)
          • pgram
            • Apr 2016
            • 37
            Edit
            Power Supply voltages at the 18 pin connector when disconnected from the main board:
            Code:
            17 (GND) 0
            15 (12V) 0
            13 (12V) 0
            11 (GND) 0
            09 (24V) 0
            07 (GND) 0
            05 (3.5) 3.45
            03 (3.5) 3.45
            01 (PWR-ON) 0
            18 (GND) 0
            16 (N.C) 0
            14 (12V) 0
            12 (GND) 0
            10 (24V) 0
            08 (GND) 0
            06 (N.C) 0
            04 (PDIM) 0
            02 (DRV-ON) 0
            The solder joints on the back of the Power Supply do look a little rough. I had originally started removing components to keep as a backup when I planned to scrap the TV, but resoldered them back on after I decided to give the TV a second go. The Weller iron I used has seen better days (I have a newer iron, but it wasn't getting hot enough to melt the solder consistently).
            These were the voltages on the odd pins:
            Code:
            1st reading : voltage change after power button pushed
            17 (GND) 0
            15 (12V) 1.7 : 3.1 > 1.2 > 1.7
            13 (12V) 1.7 : 3.1 > 1.1 > 1.7
            11 (GND) 0
            09 (24V) 23.7 : 23.1 > 23.7 > 0 > 23.7
            07 (GND) 0
            05 (3.5) 3.4 : 3.3 > 3.4
            03 (3.5) 3.4 : 3.3 > 3.4
            01 (PWR-ON) 3.3 : 0 > 3.3
            More pictures:
            • Close up of the back of the Power Board near the 18 pin connector
            • Close up of the front of the Power Board near the 18 pin connector
            • Close up of the front of the Main Board near the 18 pin connector
              It looks like the switched 12Vdc circuit is damaged.
              Need to do board tracing next to see how switched 12V is generated.
              Pictures provided by shopjimmy.
              • pgram
                • Apr 2016
                • 37
                Thanks for the pictures, this helps me out a lot. I didn't get a good picture of the back of my Power Supply Board before I started removing components.
                To start with the obvious issues, it looks like I may have made a mistake in two places when resoldering components.
                I've made 4 comparison shots with the shopjimmy board on top and mine on bottom. The first two pictures look like they could be an issue, not sure about the latter two. In the last picture, the orientation of the blue thingy on the left and the 3 resistors in the center are reversed (although I believe the orientation of the stuff on my board in this photo is the same as what it was when I removed the board).
                I'll keep looking to see if there's anything else that I may have messed up.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Hello pgram,
                  You are in desperate need of a new soldering iron or tip for it. since you really need to finish off those joints tidily or they will cause you more problems than you started with.
                  Can you check D208 on the underside of the board by the connector. Is R226 missing off the board?
                  • pgram
                    • Apr 2016
                    • 37
                    Hello pgram,
                    I'm not sure I have a replacement tip handy for my Weller soldering iron. I've been looking for one for a while and have not had any luck, none of the local electronics stores had any in stock when I went looking for parts a month or so ago. I do have another iron, but I haven't had a lot of luck with it so far. I might try changing the tip on it.
                    I don't think R226 was ever on the board, it's not shown on the replacement at shopjimmy that budm just linked to. What is the issue with C210 and D208? I'm not seeing any major differences from other nearby connectors and I didn't touch either with the soldering iron.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      The 12V supply is missing so you need to start to check components and although I'm not 100% certain I think D208 is a diode in line with the 12V supply. It wouldn't hurt to check all your diodes and zener diodes in that area.
                      C210 looks as though its got a solder blob stuck on it which can be wiped off.
                      • pgram
                        • Apr 2016
                        • 37
                        I checked all the diodes I could find nearby and I didn't find any that failed open circuit (didn't remove them from circuit though). Scratching my head on what to check next, I haven't been able to find a service manual / schematic for the TV. I found a service manual for the Asian market model at a similar size, but it had different layout in the schematic.
                        These are the readings from I got with my multimeter in diode mode:
                        Code:
                        Front of PCB:
                        D101  1 , 492
                        D105  1 , 492
                        D203  185 , 1500+
                        D205  185 , 1500+
                        F100  0 , 0
                        R222  601 , 1240
                        ZD102 1 , 682
                        ZD102 511 , 1
                        ZD103 716 , 1
                        ZD105 1 , 710
                        ZD202 618 , 1
                        Code:
                        Back of PCB
                        D206  690 , 182
                        D207  1183 , 609
                        D202  609 , 1
                        ZD203 0 , 709
                        Voltages readings (18 pin cable to main PCB disconnected):
                        Code:
                        450v 68uF capacitors (across legs)
                         EL9 to C111: 167.6v
                         EL10 to C110: 167.6v
                         EL51 to C109: 167.7v
                        C209: 3.4v
                        C222: 0v
                        IC202: 23.5v (at pin 2 / V-in)
                        P203 0
                        P202 0
                        P802 1.54
                        F100 (fuse) 0 on both sides (something seems off...)
                        Code:
                        Voltages readings (18 pin cable to main PCB connected):
                        P202 0.182
                        P802 0.113
                        LED+ 83 (P801?)
                        LED- 0.16 (P801?)
                        I found my original voltage readings from before I shorted the 18 pin connector as well. These readings make me wonder if the problem is really on the Power Supply board, the readings when the TV was powered off were almost the same:
                        Code:
                        93.2~118.5V output
                        Input listed as: 100-240~ 50/60Hz 2.0A
                        Output listed as: 133.2V - 0.37A 39 Inch
                        TV on:
                        LED+ connector: from 232V down to 214V (cycling voltage)
                        LED- connector: from 21V down to 15V (cycling voltage)
                        P801: from 232V down to 214V
                        P802: from 19.5V down to 16.8V
                        TV off:
                        LED+ connector: 81V
                        LED- connector: ?
                        P801: 82.2
                        P802: 0.36
                        Code:
                        At the 18 pin connector (P201):
                        Odd pins with TV on:
                        17 (GND)  0
                        15 (12V)  11.8
                        13 (12V)  11.8
                        11 (GND)  0
                        09 (24V)  22.7
                        07 (GND)  0
                        05 (3.5)  3.4
                        03 (3.5)  3.4
                        01 (PWR-ON) 3.3
                        Odd pins with TV off:
                        17 (GND)  0
                        15 (12V)  0
                        13 (12V)  0
                        11 (GND)  0
                        09 (24V)  0
                        07 (GND)  0
                        05 (3.5)  3.3
                        03 (3.5)  3.3
                        01 (PWR-ON) 0
                        Also, I attached some pictures I made for reference.
                          What do you use to create that x-ray version?
                            The 12V is generated by the buck converter 8-PIN DIP IC202 (and associated parts L201, D206), it takes the 24VDC input (looks like pin 2) and down converted to 12VDC.
                            We need the P/N of that IC.
                            • pgram
                              • Apr 2016
                              • 37
                              I noticed the PCB was translucent, so I shined a lot of light on one side of the board and took a photo of the other side. Then I used GIMP (image editor) to flip the photo and overlay it onto the one from shopjimmy.com.
                              IC202 P/N: NR891D (1-1-3 DC/DC Converter ICs NR887D/NR891D)
                              I wasn't able to find anything using the labeling on L201. I'm not sure what the label is on D206, maybe "B86 264P" (it's very difficult to read). I added P/Ns for the ICs, a rectifier, mosfets, and some other stuff to the second photo.
                              • thoma
                                • Sep 2012
                                • 268
                                http://televid-sib.ru/index.php?board=165.0
                                LG SMPS schematics Registration required!!
                                • pgram
                                  • Apr 2016
                                  • 37
                                  Thanks for the link, unfortunately it doesn't look like they have anything for the TV's Power Supply (EAY62810401 / EAX64905301) or L201 (it's labeled with "13S-DD06 FL 121218 F"). A Google site search didn't give me anything useful.
                                  At the same time, the Forum is post, ie Administration checks messages for compliance with these rules after their publication, in connection with what is possible when a particular message may be offensive, inappropriate content, and have parties agree to bear all risks associated with it. 9. Do not use in the name of various kinds of decoration themes (characters, intended only for visual highlight topics, but do not carry the semantic load)
                                  In addition, it is forbidden: placing and discussion of materials of a pornographic nature, placing advertisements, discussion of politics and politicians.
                                  Hard not to laugh reading this in the registration requirements when they have a big old Colorado down in the lower right hand corner, seems ridiculously contradictory.
                                  • pgram
                                    • Apr 2016
                                    • 37
                                    Actually I take back my earlier reply. I couldn't find the exact Power Supply Board schematic there, but I think I may have found one close enough to use as a guide. This one looks to have a lot of the same P/Ns (see attachment). Thanks for that link.
                                    The screenshot was taken from the schematic for the "Power supply + LED drv LGP32-13PL1 EAX64905001 EAY62810301", I think it's this board.
                                    • pgram
                                      • Apr 2016
                                      • 37
                                      More measurements after looking at the schematic in my last post:
                                      Code:
                                      Voltage readings with TV plugged in, but powered off:
                                      J44: 23.7v
                                      C217: 4.7v
                                      IC202 pin 7: 4.1v
                                      R233 (both sides): 0v
                                      L201 pin 1: 0.18v
                                      L201 pin 8: 0.18v
                                      Resistance measurements:
                                      IC202 pin 4: 0 Ohms
                                      L201 pin 5: 990 Ohms
                                      I've attached an updated picture of the top of the Power Supply PCB with better labeling.
                                        What resistance do you have between pin 3 and GND?
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • EazyBone
                                          LG OLED55C9PUA power problem
                                          by EazyBone
                                          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                          The power supply to t con is different story.
                                          This...
                                          06-23-2023, 07:43 AM
