Dead Vestel 17IPS71 power board
  • dick_barton
    replied
    Re: Dead Vestel 17IPS71 power board
    If you have no DC at the output then I would consider replacing the FAN6300A
  • fnets
    replied
    re dick_barton above "So you have rectified DC so now to find out why you have no DC outputs". I'm going to check DC output again.
  • fnets
    replied
    the information of the ic is very small so it may be a problem but the one above has 6300A MYC on it (I can only just make it out). but still haven't found the problem so how do I test this (do I need it plugged in?)
  • vinceroger69
    replied
    i hope so too the trouble is when we zoom into your pictures we cant see the part numbers etc on the ic s etc so it makes it hard to see what particular ic s etc are fitted on your psu can you try re uploading them maybe try this , click on go advanced then theirs a paper clip icon click on that and add your pictures that way.
  • fnets
    replied
    I hope we can both learn something from this.
    Here's my board
    ic probably on the underside?
    how do I test this? (also what does an led mosfet look like?)
  • vinceroger69
    replied
    the ic should be on the bottom of the board somewhere and diodes that read odd i just un solder one side lift it up from the board and retest. Im still learning myself so im hoping a more experienced member will give us some assistance to but for now do your best and follow this thread and run the tests suggested by the others.
  • fnets
    replied
    brilliant thank you. going through tests this morning starting page 1.
    I'll probably replace the ic anyway but can't find anything similar to this on the board?
    https://www.ebay.co.uk/itm/FAIRCHILD...cAAOSwc-tY3WfY
    1. voltages across C19=325v, C20=324v, C21=324v
    2. Diodes seem ok but ...
    on diode setting my multimeter (Sealey MM19) shows 1 for open line. With -ve probe on grey band side I get a voltage. With +ve probe on grey band side I get voltage and then settles down to 1 after a few seconds. If useful I can detail the results for each one (but unsure how to identify other than referring to image)?
  • vinceroger69
    replied
    this looks like the ic check on your board that it uses this ic it may not be faulty yet tests should prove either way
  • fnets
    replied
    fantastic (yes can solder)
  • vinceroger69
    replied
    a common failure on these power supplies U202 FAN6300 SMPS IC if this ic is cheap enough and you can solder ok i would probably just change the ic but if i was fault finding this board i would just follow this thread step by step and see if it points too that ic being faulty.
  • fnets
    replied
    ok thanks
  • vinceroger69
    replied
    thats ok then start with page one of this thread and follow each step, my guess its the same ic thats failedin this thread, see how far you get and what voltages you get etc but if that ic has failed its probably why you are getting no voltages on that connector
  • fnets
    replied
    just tried on 1.5v "C" Duracell and meter ok on DC setting?
    I also tried testing the diodes and I think they're ok (but this is the first time I've tested a diode).
    the capacitors look ok but haven't tested them.
    the TV wouldn't switch on and had no standby light.
  • vinceroger69
    replied
    start from basics get a new battery a aa or 9v one and check your meters working fine on dc measurements i will have a look in the schematic while your testing that as i have not worked on one of these boards before
  • fnets
    replied
    nothing, tried pins 1,3,5,7,9
    sorry to cause confusion but I also started https://www.badcaps.net/forum/showth...064#post781064
  • vinceroger69
    replied
    do you get any voltage on any of the pins? of cn4
  • fnets
    replied
    if possible I'd like to know how you word this correctly?
  • fnets
    replied
    tested this morning. 240V AC going in and 0V DC going out on pin 9.
  • vinceroger69
    replied
    yes black probe on ground a mounting screw is the easiest
  • fnets
    replied
    back tomorrow. thank you very much.
