Emerson LF501EM4F turn on then off.
  • erickeri1234
    replied
    Re: Emerson LF501EM4F turn on then off.
    Small ribbon goes to the ir board.
  • CapLeaker
    replied
    Where does that ribbon on the bottom left corner on the main board go? It looks like it goes to the Tcon for me?
  • erickeri1234
    replied
    Pic
  • erickeri1234
    replied
    One ribbon going to the tcon.
  • erickeri1234
    replied
    So when the TV comes on for 8 seconds the TV acts normal (you can see picture on the LCD) and then the TV turns fully off? That is a main board problem in my book. So verify the PSon pin on the power supply again. If the PSon voltage drops out, it is the main board. PSon is generated on the main board. Try the same thing with the back lights unplugged, then with the Tcon unplugged. Are there 2 ribbon cables going to the tcon?
    Yea tv will power up I see the Emerson logo then for split second I can see the channel, then the tv goes turns off fully when speakers make like a small popping noise like the board is shorted. It does it with everything connected and when I disconnect everything. I just tested the power supply again samething.
    PS_ON-H2 ..... 3.2v then drops to 0.0v when it shuts down
    P-ON+21V.... 21v then to 11.5v when it shuts down
    All+3.3v..... 3.279v there all the time.
  • CapLeaker
    replied
  • erickeri1234
    replied
    measure the voltages on the back light led strings.
    Hard to measure no diagram on board.
    It does it even when everything is unplugged . Just power to main.
  • CapLeaker
    replied
  • erickeri1234
    replied
    UPDATE!!!
    Git the main board in from SJ, installed it and it is doing the samething. Turns on for about 5 to 8 seconds then right off. So I ordered a PS board samething on then right off... should I RMA the main board??
  • erickeri1234
    replied
    Ordered the main board today. Will post out come
  • erickeri1234
    replied
    yeah... you only have PSon jumped to fire up. You would have to do the same thing to BLon (backlights). There is nothing wrong with your PSU.
    It's got to be the main then right. It does seem like it.
  • CapLeaker
    replied
  • erickeri1234
    replied
    Originally posted by dick_barton
    When doing the above test did the backlights come on and stay on?
    OK tested it with the backlight connected to the PS board. The back light doesn't come on.
    But it does come on when main board is connected. Weird!!!
  • erickeri1234
    replied
    Must be a bad resistor. Some resistors go high in value if there is current going through it, but measure fine out of circuit or if the unit is turned off. I've had that happen before.
    Yea something was up with it. I grabbed a different resistor 1.2xx and I got some readings.
  • erickeri1234
    replied
    I disconnected every from the PS board. But I will plug the backlight in and see.
  • CapLeaker
    replied
    Originally posted by erickeri1234
    Im trying to jump it with a resistor that I'm reading 1.032 but I'm getting 3.3v at the end but once I touch the p-on_h2 it drops down to 0.57v
  • dick_barton
    replied
  • erickeri1234
    replied
    Ok I tested with a different resistor and jumped all3.3v to p_on-h2 and got 12v on 13v rail. And got 21v on the 21v rail..
  • erickeri1234
    replied
    No, any 1K will do.
  • dick_barton
    replied
    No, any 1K will do.
  • waakye
    ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
    by waakye
    I was giving this ASUS ROG G750JM that exhibit the following behavior:
    When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
    My issue is the laptop doesn't stay on for a long time and turn itself off.
    Any lead on how to resolve this will be appreciated.
    I cannot boot in windows and no liquid damage.
    Thanks in advance.
    09-13-2024, 08:10 PM
  • gabrielA7
    IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
    by gabrielA7
    Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
    I saw that the room LED lights up only when the screen is connected, so quiet.
    We have all the power supplies, even processor, 1.8V
    One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
    I suspect that there may be some leak in the processor.
    Anyway, when I press the power, it...
    10-29-2024, 06:48 AM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • JohnML1975
    Falcon FF32S53 turns off by itself then will not turn back on unless you wait
    by JohnML1975
    Dear Forum members
    I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
    I will upload some photos and share my trouble shooting steps so far
    07-20-2025, 12:28 AM
  • RdeveLabs
    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
    by RdeveLabs
    To all the members here...
    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
    05-05-2025, 04:59 AM
