LG LE37LH4000-ZA Tcon Issue?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Picked up this set. The original fault was described as taking 30 – 40 mins for a full picture on the screen from switch on cold. Initially there would be only several horizontal lines across the top of the screen and over time this would build up to form a full picture.
    Removed the ribbons to clean the contacts after which I no longer get a picture.
    Everything else is working and I can play a DVD through the TV, raise the volume up and down, mute the sound etc.
    Pictures showing screen with no ribbons removed between the Tcon and panel. Next only the left ribbon removed and then finally the right only ribbon removed.
    With the DVD player removed and using a scope, I can see data going from the main board to the Tcon when monitoring one of the data lines. Selecting and deselecting the Menu button on the remote flicks between the two screen shoots. The amplitude of the signal on the data line appears to be less than 0.5V and I am unsure if this is normal.
    There is 12V dc on the Tcon board.
    Suspect the Tcon needs to be replaced.
  • comptek
    • Aug 2013
    • 606
    Re: LG LE37LH4000-ZA Tcon Issue?
    study lvds cables to screen inspect them as you may have lifted trace cleaning them i have managed it once
    as for the screen issue pretty common for tab bond failure
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Does look like Tcon to me, good method of diagnoses too I need to get a scope soon. Also check the Lvds signals coming out the Tcon after the amplifiers see if its similar to what the mainboard is outputting. Would you rather just replace it or try to debug it ?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Hello Comptex, That's the first thing I thought I may have done so I removed, inspected under a magnifying lamp, OK, then re-inserted the cables. Thanks for your input.
        Hello ReeceyBurger123, That's the conclusion I reached but was ineterested in other peoples view. Thanks to for your input.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Hello ReeceyBurger,
          I'd like to try and debug it since there's no fun in replacing it but I'm unfamiliar with their mode of operation so wouldn't really know where to start.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Will have a look see if I can find a schematic for this pcb.
            • comptek
              • Aug 2013
              • 606
              ok cool
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                When it comes on Dick does the little blue light come on ?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Initially it did. It would flash a few times. I need to take a look and see what state it is now and be back in a few mins.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ok one thing to check it the transistor Q401 underneath the blue Led that I belive fails on these. Not sure what it does as cant find any schematics for it.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Not anymore. As I said when I powered it up "prior to cleaning the ribbons" I'm fairly certain it would flash quite a few times.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Thanks for the hint. This will be a job for the morning.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          The light should come on to show that the Tcon processor has been turned on, keep us updated bud
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Will do
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              I've now had a chance to do a bit more checking on the Tcon board.
                              The blue light on the Tcon flashes only once but extremely briefly at switch on.
                              Lifted Q401(mosfet) out of circuit which checked OK.
                              Measured the voltages around the MAX17108 which is a 10 Channel High Voltage Scan Driver.
                              Gon1 = 26V
                              Goff = -9V
                              Gon2 = 26V
                              Pos = 6.8V (Opamp positive/ non-inverting input)
                              Neg = 6.8v (Opamp negative/inverting input)
                              The 8 pin IC's appear to be running at 3.3V
                              Looking at the data sheet for the panel LC370WUH (SB)(A1) I believe the above voltages are within the driving specification of the panel.
                              However, monitoring the inputs A1 through A10 of the MAX17108 IC, there appears to be no input signal and therefore no output signals at Y1 through Y10.
                              It looks as though the video signals has been lost somewhere between entering the Tcon board on route to the MAX17108 panel driver.
                              I have now ordered a replacement and will let you know the results.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Update:-
                                The replacement Tcon arrived today and the blue led on it does indeed stays on until the backlights fire up, then the picture, before it goes off.
                                The original fault described was that the picture is scrambled (see photo's) and this is still the case however it return to normal within a few minutes.
                                The set has to be off at least an hour or so before you can repeat the scrambled screen at switch on.
                                The only other hint is that while in the scrambled state the picture freezes when changing channels for 2 to 3 seconds. The sound is fine.
                                I've check the voltages of the main board regulators and they appear to be OK. 3.3V, 1.8V, 1.2V and 5V.
                                The power supply voltages read as given on the PSU label. 5.2V, 12V, 20V and they to read OK
                                Any suggestions welcome?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Here's a video link showing the fault as best I can.
                                  I would be interested in your opinions as to whether or not it a video fault or a panel problem?
                                  https://youtu.be/zzpYIInTmNY
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Further update.
                                    After gently warming up the circuit board connecting the panel to the tcon board with a hair dryer for a few minutes, the set turns on and behaves itself perfectly.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Tab bond issue then bud.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        That was my fear too.
                                        I'm hoping that pressure on the offending component may solve the problem. Warming up makes it work so I feel its a connection problem. Will take a look at the tab-panel board for any suspect joints as well.
                                        Will let you know.
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • wizard13
                                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                          by wizard13
                                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                          • Part Number (P/N): PYU13E-00C00PFR
                                          • Serial Number (S/N): 22028896H
                                          • System Configuration (SC): A1PYU13E1127
                                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                          • Power Input: DC 19V –
                                          02-28-2025, 02:43 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
