Hisense 32K20DW missing LED voltages and 6 blinks
  • steves7839
    • Nov 2014
    • 200
    Hi All!
    I,m troubleshooting a Hisense 32K20DW that won't turn on.
    5VSTB is present when the set is off. When turned on, 12V are present, SW >4V. No sound, video or backlight. The STB LED blinks 6 times, then goes off.
    Here are the pins and voltages at the 10-pin connection to the Main Bd:
    ON:
    STBY 0V
    12V 12V
    GND 0
    16V 0V
    SW 4V
    The same pins when OFF (the standby LED on the bezel is red):
    STBY 5V
    12V 12V
    GND 0V
    16V 0V
    SW 4V
    Strangely enough, the largest cap C829 reads both 178VDC and 368VAC across it's leads with my VOM.
    Other caps on the PSB and their on voltages follow:
    C827,828 45V
    C855,861,862 12V
    C717 by LED pwr 0V
    I suspect power supply, would greatly appreciate knowing if these factors point to any specific component.
  • CapLeaker
    Leaking Member
    • 8146
    Re: Hisense 32K20DW missing LED voltages and 6 blinks
    The large cap reading 2 different voltages is normal. The lower voltage is rectified mains, the higher voltage is boosted PFC voltage. From what you are saying, the main board is turning the PSU on, but the 16V rail is dead. So either there is something wrong with the PSU on the 16V rail or the main board is dragging it down. You can try forcing the PSU on without the main board attached and check if the 16V reappear. Or try to take the 16V pin out of the connector?
    • steves7839
      • Nov 2014
      • 200
      I separated the PS from the Main Board and jumpered 12V to ST on XT802 with a 1.2K resistor (since STB was not present, it seems to be made on the MainBd.)
      Still no 16V.
      The attached photo shows the rear side of the PSB. V712 and V713 look like voltage regulators. One has 46VDC on the large solder tab, but nothing on pins 1 or 3. The other has no DCV on any pin or tab.
      I'm digging through the attached Hisense schematics elsewhere on the web site. If anyone has a link to RSAG7.820.5338 PSB and RSAG7.820.5555 Main Board schematics please point me there!
      Thanks for reading!
      • CapLeaker
        Leaking Member
        • 8146
        I was able to look at that PSU over at SJ on the front and back. Looks like the 16V is not installed on yours. The cap C853 and diode VD819 are not installed on your board. So you can't have any 16V.
          What happen if you disconnect the LED connector XP804, will TV boot up OK?
          What dcv do you have between the legs of cap C717?
          • steves7839
            • Nov 2014
            • 200
            "What dcv do you have between the legs of cap C717?"
            None. 0VDC. Even with the XP804 LED power disconnected, I measure no voltage at those pins.
            I have 45VDC across C827 and C828. Seems like higher voltages would have to come from here.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              It may be worth checking VD705 & Q701.
                C717 is the filter cap for the LED power supply boost converter output so the power supply is dead at this point even though you do have 'SW 4V' to turn on that LED power supply section, so more in-depth troubleshooting of the power supply board will be required to get down to the component level.
                Boost converter has L701, Q701, D705, and there should be LED controller for the LED power supply.
                • steves7839
                  • Nov 2014
                  • 200
                  Q701 is the tab for V712 which is at 45VDC and appears at LN on XP804. C715 and C716 in parallel appear to couple something to LP, which reads 0VDC. VD705 has good forward drop, .45 in Diode test. Looks like I should pull C715&C716 for out of circuit test....?
                    can we see the straight shot pictures of the whole bottom side of the board? There should be an IC controller for the LED backlights.
                    Right now you have 45V input to the boost converter but no boosted output Voltage for the LEDs.
                    • CapLeaker
                      Leaking Member
                      • 8146
                      courtesy to SJ
                      http://assets.shopjimmy.com/media/ca...180-bottom.jpg
                        IC N803 is the LED Backlights controller.
                        MOSFET V713 is the PWM controlled for the LED string (Cathode) return side.
                        • steves7839
                          • Nov 2014
                          • 200
                          V712 has 40.5VDC at the tab and at XP804 pin LN. V713 shows no DCV at any point. It's tab is tied to XP804 pin LP.
                          What are the key pins to probe around N803, the controller IC?
                          On the photo of VD811 and V807 on the top side of the PSB, what is the significance of 180 VDC on the center lead, which appears to be a diode?
                          What range of voltage should I be looking for on the return side of the LED supply?
                            I think you have measurement error, the LP pin of the xp804 connector is the boosted output pin to the Anode of the LED string, this LP pin is connected to the Cathode of the diode VD705 and it is also connected to the + pin of the C717 (filter cap for the booster circuit which you said it shows 0 VDC between the two legs of the cap), the Anode pin of the Diode VD705 is connected to the output end of the inductor L814, input end of the inductor L814 is connected to the big tab of MOSFET V712 which you indicated that you have 40VDC on the tab, so it must be measurement error to have 0 VDC on the capacitor C717 unless the inductor or the diode has open circuit. You need to verify that again, I am sure that you should also have 40VDC at the LP pin of connector XP804.
                            If you trace out the connection at the bottom side you will see what I have describe how the circuits are connected together.
                            Right now 40V is just an input Voltage to the booster circuit and it is not being booster high enough to light up the LED, I expect it to be around 70~80V range.
                            We also need the P/N of that LED controller IC.
                            BTW, the LN pin is the Cathode return side of the LED string.
                            Pictures provided by shojimmy:
                            http://www.shopjimmy.com/hisense-167...upply-unit.htm
                            • steves7839
                              • Nov 2014
                              • 200
                              V712 is shorted pin to pin. I confirmed this by raising one leg. MDD1904 is printed on the FET. It's a good part number so I'm going to order a couple.
                              The 14-pin voltage controller N803 has a number BB0533GP.
                                The picture you show: https://www.badcaps.net/forum/attach...4&d=1462678576 is for V713 (MDD1904) which is for the Cathode for the LED string return.
                                <1 Ohm reading between pin ? and pin?
                                • steves7839
                                  • Nov 2014
                                  • 200
                                  I measured 0.2 ohms or so between S-G, G-D(tab) and S-D, even after desoldering and lifting the S leg.
                                  • steves7839
                                    • Nov 2014
                                    • 200
                                    Replaced V712 with a new FET. Set is back to original symptom: It powers on with 6 blinks of the STBY LED which then goes off. No sound or backlight appears. The voltage across XP804 LED power: 84VDC with LED string disconnected, return side rises to 24VDC when string is connected. Is this consistent with a bad LED string?
                                    The Main board produces SW-ON 3V, 12V to the T-CON bd, 1.5, 3.2V and 5V. No response to flexing or heating.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      So what voltage do you have at the LED connector with the leds disconnected?
                                      Edit:
                                      Ignore since you already say above which I missed.
                                      But do the backlights flash no matter how breifly at all when you power up?
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        I believe the led voltage should be 150V at 400mA as written on the power supply board.
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • karlp028
                                          MSI Z390-A PRO missing VCORE voltages
                                          by karlp028
                                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                          06-23-2025, 01:25 AM
                                        • RossMoodley1967
                                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                          by RossMoodley1967
                                          Hello
                                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                          03-01-2024, 06:07 AM
                                        • mat2k
                                          Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                                          by mat2k
                                          Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                                          BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                                          I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                                          12-01-2024, 11:00 PM
                                        • MrCreosote
                                          HiSense 55HtB power supply bench test: weird voltages
                                          by MrCreosote
                                          There was a power surge at home from "direct" (no sound delay !!!) lightning strike. Popped a 15 amp breaker for ceiling lights (old knob and tube wiring - perfect antenna?) "Fried" garage door opener buttons and remote, KVM switch, Magic Jack, and a ceiling fan motor.
                                          And my 55" 6 year old Hisense Black Friday Walmart TV.
                                          There is no Red standby LED.
                                          I was wondering how to "jumper" the board on to test voltages thinking the STB pin would be one of the pins.
                                          However, I decided to measure voltages at all 10 pins...
                                          08-12-2021, 11:20 PM
