TC-P50VT20 10 Blink Code
  • tw2005
    • Oct 2011
    • 6458
    Re: TC-P50VT20 10 Blink Code
    Originally posted by Katzat
    I figured out that the SU and SD boards are the buffer boards. The test points on my board were different than those shown in the Troubleshooting handbook, but I was able to do the tests from the pinouts and got roughly the readings specified.
    The 5V_F reading on the SD board was roughly 10 MOhm Rather than the 5.7, but it was definitely not shorted.
    As soon as I hear from you regarding the troubleshooting anomaly above, I'll wrap this up and send this for rebuild.
    There's three resistance test points to test. Vfo is a good one to check as it will go short on a bad board in most cases
    • tw2005
      • Oct 2011
      • 6458
      TW, I hate to bother you again, but I was reading through the Troubleshooting handbook you gave me trying to find the word Buffer (to test the buffer resistance) and I couldn't find it. Is there another word for buffer or a specific page for that procedure.
      Also, as I was pouring through that manual, I found it was WAY more useful than the similar manual I have for my specific TV. It actually has a 10 Blink Code troubleshooting procedure. So, just for fun, I decided to run through it just to prove what I think I already know (that the SC Board is bad).
      But when I run the procedure on page 53, I get to the point where I disconnect SC20 and power the unit on, and I still get the 10 blink code. according to the procedure, it would appear that my problem is in the A Board based on that. If the SC Board is the culprit, the procedure says the LED should blink 6 times with SC20 Disconnected.
      Is this an error in the procedure or is the VT20 different than the G series TVs?
      Well for me if you found 6 shorted out IGBTs on the SC board then there's really nothing more to be said about that.
      Of course I'm relying on data you have posted but all the ones you say are shorted are generally always shorted when these boards fail.
      What you're worried about I presume is , is it really causing 10 blink.
      It's definitely known to cause 10 blink, and we know it's bad.
      So where are we heading now? Looking for a second board that failed?
      Possible I guess, I have had a blown SS board and a faulty A-board in one TV.
      I guess I'll have to come up with a way to prove it is not.
      If It was the 2D model I have an easy way but this has a d-board so i'll have to think about it.
      • tw2005
        • Oct 2011
        • 6458
        Step 1:
        Is there a short circuit of the Vsus, Vda, or P15V? Follow the procedure on page 8 to check the Vsus, Vda, and P15V for short circuit or low resistance reading.
        what resistance values do you get particularly on the P15V and, Vsus (across the SC2 pins).
        • tw2005
          • Oct 2011
          • 6458
          Try this.
          TV off.
          disconnect:
          SC board
          SC2, Sc20,
          SS board:
          ss11,
          P-board:
          P35, P65,
          D-board:
          D31,D32,D33,D34
          turn the TV on, I expect the fans will be running if it's on.
          Once you've confirmed a result, turn it off and leave it for about 10 mins before you reconnect any of those leads especially P35,P65 or you can arc the panel due to residual voltage.
          • Katzat
            • Mar 2016
            • 23
            Originally posted by tw2005
            Step 1:
            I did that test as well. All was good according to the manual. All more that 1kOhm.
            • Katzat
              • Mar 2016
              • 23
              Since I know the SC Board is toast in all the normal places, I think I'll just send that one for repair and fix something else if if necessary after that's fixed.
              • tw2005
                • Oct 2011
                • 6458
                SC2 can read 300k-over 2 megohms so it would be interesting to know the measured value.
                A generic value of 1k or over being classified as not shorted or low reading for SC2 is unrealistic.
                These guides are not always accurate.
                you could try my other suggestion, I'm thinking it should either turn on or go 6 blink.
                • Katzat
                  • Mar 2016
                  • 23
                  P15V = 2.5 kOhm
                  Vsus = 5.7 MOhm
                  Vda = 4.2 MOhm
                  I've since removed the SC, SU, and SD boards in preparation for sending the SC Board for repair. Could the other test still be performed with those out of the set completely to see if I get 6 blinks?
                  • tw2005
                    • Oct 2011
                    • 6458
                    P15V = 2.5 kOhm
                    Vsus = 5.7 MOhm
                    Vda = 4.2 MOhm
                    sure, I am somewhat curious to find out what it does.
                    interesting results. So 5.7Mohms across SC2 ?
                    • Katzat
                      • Mar 2016
                      • 23
                      Yes. It is decreasing. I guess there's a cap in the circuit that's biasing a transistor gate or something. I didn't wait to see how low it would go, but it's definitely not shorted.
                      I'll run that test tonight and report back.
                      • Katzat
                        • Mar 2016
                        • 23
                        OK, It took me a couple of evenings, but I ran the test with everything you specified disconnected.
                        Yes, the fans ran when it was turned on, but it never shut off and I got no SOS code. No 10 blinks and no 6 blinks. It was like it thought it was running just fine.
                        The SC board has been sent away for repair and I'm now waiting for it to come back for reassembly.
                        • tw2005
                          • Oct 2011
                          • 6458
                          That's a good sign. Should be happy days
                          • matu
                            • May 2016
                            • 10
                            • Estonia
                            #33
                            Hi, i have a similar problem discussed above but refer to model
                            TX-P42VT20. Well, continiously this TV gives me 10 blinks error code when switched on. I have changed the main A board for the beginning which didnt give a result. Then I changed the SC board, following with D-board, no big difference still 10 blinks error. All transistors and diods are checked on SC boards for short before installed by my tech.friend also SS boards seems to be working. If I switch tv on with orig. videoboard, on the board the optical red lid is on. I did the test described here(i dont know is it suitable for that model also):
                            SC2, SS11, P35, and the 3 white ribbons(only one wide white ribbon present) on the side of the A-board.Now turn it on, if it turns on and no error blinks the P and A are ok. Do this for less than 30secs." Still the same!
                            All boards ordered are matching labels and asked for 42" model.
                            One weird case if i swap between A-boards, then switching tv on with orig. A board the green lid blinking longer time then turn back to 10 blink error code. Ther is only one board i havent changed - the SS, regards to 10 blink error code. But before to make another investment, i need to be sure. So, would be very grateful for any help how to find the failed one.Thanks
                            • tw2005
                              • Oct 2011
                              • 6458
                              This being a 3D model makes it a bit different especially the " 3 white Ribbon "bit but if you read above what was done The TV turned on with no error blinks? Did you read the previous posts?
                              Have the TV off, disconnect SS11, turn it on and post up what happens
                              • matu
                                • May 2016
                                • 10
                                • Estonia
                                #35
                                no. there is always only 10 blinks, SS and SC disconnected both or only one at time. Two second green flashes, relay click and 10blink failure code.nothing on the screen.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Try the instructions in post 24 watch out for residual voltages after each power cycle .
                                  Especially p35 p65 that feed the c boards and panel
                                  • matu
                                    • May 2016
                                    • 10
                                    • Estonia
                                    #37
                                    Thats what i did:
                                    TV off.
                                    disconnect:
                                    SC board
                                    SC2, Sc20, - disconnected, same numbers on my SS board
                                    SS board:
                                    ss11, - disconnected from P-board P11, SS11 cant reach
                                    P-board:
                                    P35, P65, - on my board there is P35 and P6( which is connected to A-board),both disconnected. P25 goes to D-board, stay connected.
                                    D-board:
                                    D31,D32,D33,D34 - on D-board there are D31 and D32 (disconnected both).
                                    Others D20 disconnected from SC board, D5 connected with A-board.
                                    And result is - there is no difference in behaviour.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Ok looks like i need to look at a manual. Obviously the 42 is different. No c boards along the top just the bottom by the sounds of it in which case some of those are missing. P6 needs to be connected.
                                      Got 10mins of tv to watch then i can get on my pc.
                                      • matu
                                        • May 2016
                                        • 10
                                        • Estonia
                                        #39
                                        yes, only two c boards on the bottom.I can provide photo from the back if needed. Thanks for your efforts
                                        • Katzat
                                          • Mar 2016
                                          • 23
                                          TW, you are doing the Lord's work. Thanks so much.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Yesterday, 05:17 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
