VIZIO E550i-B2 Sound - No Video Problem
  • kevinm34232
    • May 2012
    • 1884
    Re: VIZIO E550i-B2 Sound - No Video Problem
    sorry ya i thought I had posted a pic, but it is just basically the left half of the screen perfect pic, with a blank right side. I have checked the components not finding anything wrong so far. What's the process of removing the side tabs? I've already considered the panel bad so nothing to lose trying..
    • budwich
      • Jul 2015
      • 3097
      you basically tear all the tabs on the right side off. They are thermally bonded to the screen as soldering at the manufacturing stage would be detrimental to the panel at that point. But this may only work IF there are tabs on the other side of the panel to drive the screen.
      • kevinm34232
        • May 2012
        • 1884
        There are tabs on both sides. I'll give it a try and see what happens.. Thx
        • kevinm34232
          • May 2012
          • 1884
          Nice job budwich! Can't believe the panel survived the abuse I put it through!
          The biggest tragedy was the front bezel/frame that holds the panel in, all the tabs broke removing it, so I will have to glue it or leave some tape on it.
          Appreciate the help immensely!
          I'm curious, why do all tabs need to be removed, and what are we solving exactly?
          • budwich
            • Jul 2015
            • 3097
            something bad has happened to one tab. It is causing "loading" across the panel which affects mostly timing of the signals. Removing the tabs takes that away. Of course, the set has been "saved" BUT no manufacturer puts in "things" that can be easily dropped or removed. The set will have some "compromise" and ultimately the tabs on the other side will have to work harder which will shorten their life span... but for now, enjoy your set.
            • Shane711
              • 493
              Wow, So I was working on this TV today but before I even opened it I came onto Badcaps Forum and see what I could find. Sure enough my connector from the Power board to the LED Driver board is like barley hanging on. So I just added super glue between the plastic and the board and after I resolder it I will add Gorilla Glue to the top. I will do the same for both sides.
              • SLK001
                • May 2014
                • 264
                I wouldn't glue it like that. You never know when you might have to actually pull the two boards apart. It is better to assemble the two boards together, then solder the broken joints, then reinstall in the chassis as a single unit (both boards connected). This will minimize the stress on the joint and since it doesn't move, should last a long while. My VIZIO has been working since I repaired the connector and started this thread.
                • Shane711
                  • 493
                  Yea, I thought about that afterwards. Would have been better to solder in wires. But I just glued the connectors down, I didn't glue the boards together. TV is working perfect.
                  • SLK001
                    • May 2014
                    • 264
                    Update on my repair
                    I turned on the TV a couple of days ago and all I got was the audio - no video. I figured that it couldn't possibly be a repeat of the original problem, so I searched all the boards looking for a tell-tale black marking of a blown component. None were found, so I took off the power supply board to look at the bottom. I didn't see anything obvious and, just as a lark, I looked at the connector between the two boards. This is what I saw:
                    Once again, all of the joints were broken.
                    A closeup of the connector:
                    To permanently fix the problem (I hope), I decided that that connector had to go, so I removed it from the boards. I replaced it with some 22ga wire with some tubing slide over the wire for insulation. The wires are arced to have some slack for whatever is causing the failure. Some photos of the modification:
                    Hopefully, this will be a permanent fix, like I hoped that the first fix would be. The first fix lasted about 22 months - let's hope that this mod lasts the life of the TV.
                    • DRayT
                      • May 2018
                      Re: Another one fixed!
                      Originally posted by SurrealMustard
                      Add me to the list of people who have had to fix this rather silly issue. Fresh solder on the connections and hot glue on the connector brought this Vizio back up. That connector seems to have been designed to fail just outside of the warranty period .
                      In this particular case, it wasn't even powering up at all. The white power light would slowly pulse and then the thing would eventually just give up. Every single point for that connector had broken free.
                      Yep, same problem here, joint looked almost exactly like the one in the pic. A minute or two with a soldering iron and it works just fine.
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        #51
                        Worked for me also.
                        • SLK001
                          • May 2014
                          • 264
                          Which mod did you guys make? If it was the first mod, then expect to have to redo it in two years or so. The last mod (in reply #49) should last the life of the set.
                          • tvtimmy
                            • Mar 2015
                            • 1160
                            • usa
                            #53
                            I did the first repair. I glued down the connectors after I reinstalled the boards.
                            • triplefour
                              • May 2014
                              • 1747
                              thank you SLK001 for taking the time to post this solution. I saved one of these TV's and now i will keep an eye out for more of them!
                              Don't fear the repair...
                              • DRayT
                                • May 2018
                                I just resolved the existing connector... if it breaks again, I'll get some new connectors and some ribbon cable and fix it the way Vizio should have made it.
                                • MarcosDaGeek
                                  • Oct 2018
                                  Re: Update on my repair
                                  Im going to attempt this as a novice. I cannot find the wire you used or the insulation. The ones that I found are not clear. Will this work?
                                  https://www.frys.com/product/7716128...hoCVJAQAvD_BwE
                                  • SLK001
                                    • May 2014
                                    • 264
                                    Any insulated wire (22 gauge) will do the job - in fact, using insulated wire is probably easier than using uninsulated buss wire with plastic tubing (it's what I had on hand at the time). It is probably easiest to use a solid wire with insulation, as opposed to stranded wire, for a novice. Do the inner wires first, then do the outer. It's not difficult, just cut and strip the wires as a set, take your time and you should be okay.
                                    • tvduude
                                      • Jul 2012
                                      • 67
                                      thx OP.
                                      someone just gave me a Vizio E470i w/ no video.
                                      i bet this is the trouble.
                                      looking forward to opening it up to find out!
                                      seems silly to make a rigid connection between the two board like that.
                                      any flex in the chassis or any approaching angle while joining them would stress the connector. what happened to good ole flexible wire?
                                      • SLK001
                                        • May 2014
                                        • 264
                                        Originally posted by tvduude
                                        thx OP.
                                        The E470i doesn't have this connector. Your problem is most likely a bad LED. Easy fix, I've done a couple of them. Use a flashlight to verify that you have video, but no backlight.
                                        • tvduude
                                          • Jul 2012
                                          • 67
                                          sorry,
                                          yes i opened the thing shortly after that post.
                                          completely different internals
                                          yes video no backlight.
                                          off to find a E470i thread.
                                          • ajshoe
                                            vizio E60-E3 backlights, sound, no video
                                            by ajshoe
                                            Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                                            Does this mean remove right side (from front of TV) tabs ?
                                            Like a second opinion before possibly destroying set....
                                            04-07-2023, 01:59 PM
                                          • soeren
                                            A2442 - No sound over internal speakers and no video playback
                                            by soeren
                                            I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                            All happened after the battery ran out of power overall several days when I was on vacation.
                                            I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                            07-26-2024, 01:24 AM
                                          • JRade
                                            Audio video receiver KENWood KR-V990D,no sound
                                            by JRade
                                            When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                            The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                            I replaced the capacitor C303/0.047F, nothing changes.
                                            I'm asking for help, what should I do next?
                                            Thanks in advance!...
                                            08-05-2025, 10:23 PM
                                          • FrancescoV
                                            Onkyo HT-R390 no sound output, video output ok
                                            by FrancescoV
                                            Good morning everyone,
                                            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                            The firmware reported is the following:
                                            M:1.00/11107BLP
                                            D:?.??/????????
                                            O:1.00/11107AL
                                            The DSP firmware given the question marks seems corrupt.
                                            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                            05-11-2025, 02:59 AM
                                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                            09-12-2024, 02:00 PM
