eax64905001 No Pfc Help ?
  • snopy44
    • Aug 2015
    • 12
    Re: eax64905001 No Pfc Help ?
    no just the blinking leds and not powering up
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ok have you checked any voltages yet ?
      • George266
        • Apr 2014
        • 12
        • United Kingdom
        I have got the same problem here- LG 32LN570R, but the board is the same tan the one mentioned in the comments above.
        The PSU board is eax64905001 ver. 2.4
        I can see the image on the display when I use torch , therefore the Backlight is not getting voltage I believe.
        I have measured the voltage to backlight, which fluctuate between 11V -21V
        Other voltages on PSU board seems to be right 3,3V , 3,47V , 12V and 24V.
        Any ideas which part is causing this ?
        Thanks for any help
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Thanks for any help
          Led driver Ic imo replace that. Video coming soon.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            How you a multimeter mate ?
            • gurug
              • Mar 2015
              • 27
              • Slovenia
              #26
              Thanks for any help
              I have exactly same problem, voltage to backlight fluctoates between 11-20V. I replaced MAP3202 - but problem is the same ... can you help me to further diagnose fault?
              Thanks in advance.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Check the 24v diode and the Led mosfet for S/C that could be pulling the 24v low.
                • gurug
                  • Mar 2015
                  • 27
                  • Slovenia
                  #28
                  Can you tell me which diode and mosfet is that? And what diws s/c mean? Voktages on connector to main board are all ok, 24v also.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    S/c means short circuit if you upload a picture of the top and bottom of your power supply im sure we can pont them out too you unless reece knows the location number already
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      Can you get us an image of the underside of the Pcb please ?
                      • gurug
                        • Mar 2015
                        • 27
                        • Slovenia
                        #31
                        PCB is same as listed on first page of this thread, I attached pictures. And also schematics of power supply.
                        • gurug
                          • Mar 2015
                          • 27
                          • Slovenia
                          #32
                          On C204 and C214 voltage is fluctoating from 43 to 48V ... if this helps to diagnose?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            So on the connector its 0-20v then on the cap which is the Led output filter its 48v ? I dont see how you measured this as the cap goes straight to the connector ? Seems to me like the controller is still bad, or something that feeds it is bad.
                            • gurug
                              • Mar 2015
                              • 27
                              • Slovenia
                              #34
                              Yes on connector is from 11 to 20V. And on C214 is like I said. And it's not going straight to connector, see attached schematics.
                              • gurug
                                • Mar 2015
                                • 27
                                • Slovenia
                                #35
                                I'm measuring C214 directly and LED connector also directly I use + and minus on connector...
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  Ahh yes I see my bad I got confused with the other cap. What VCC is going to the mosfet ?
                                  • gurug
                                    • Mar 2015
                                    • 27
                                    • Slovenia
                                    #37
                                    Can you tell me which mosfet you have in mind?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      Q801 matey, I have a video on this set being uploaded next week of how I repaired it.
                                      • gurug
                                        • Mar 2015
                                        • 27
                                        • Slovenia
                                        #39
                                        I thought your problem was only with MAP3202?
                                        On mosfet middle pin gets 43 to 48V - from L801
                                        • gurug
                                          • Mar 2015
                                          • 27
                                          • Slovenia
                                          #40
                                          I disconnected mosfet q801, and i got 46V on led connector and no fluctuation... does that mean that q801 is bad?
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • THE GTC
                                            Insignia NS-37D20SNA14 intermittent LEDs
                                            by THE GTC
                                            So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                            When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                            11-03-2020, 02:40 AM
                                          • pni
                                            Backlight panel diffuser melt by backlight leds broken
                                            by pni
                                            Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                            10-12-2025, 12:08 AM
                                          • VitalComputing
                                            Replacing Mode Indicator LEDs
                                            by VitalComputing
                                            I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                                            I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                                            I thought I could just put a resistor...
                                            09-17-2023, 04:43 PM
                                          • jimbofz
                                            just a quick question do all qled leds appear blue when fault finding ?
                                            by jimbofz
                                            i have replaced many leds strips that have changed blue when they are worn
                                            and the new replacements are perfect white
                                            but when fault finding do quantum leds always look blue?
                                            08-28-2024, 06:51 AM
