Pioneer lx6090 No image but sound working
  • kamei10
    • Feb 2016
    • 44
    • Belgium
    I know somebody with a lx6090 that have no image anymore, the sound still working and no blinking leds
    Somebody now what the problem can be ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Pioneer lx6090 No image but sound working
    Why start a new thread ? Have you checked Vsus ?
    • kamei10
      • Feb 2016
      • 44
      • Belgium
      Its over an other tv, otherwise the other thread will be a mess as both have different problems.
      Nothing checked as the tv is not here
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ohh ok, well ask them to make the room dark and see if the screen glows slightly.
        • kamei10
          • Feb 2016
          • 44
          • Belgium
          Yes it glows up but only for a very short time
            Power light blinking blue?
            • kamei10
              • Feb 2016
              • 44
              • Belgium
              No, fixed blue light. He told me that the tv had also a story
              He bought this one as faullty with 3 red leds blinking, repaired 2 Fets on the ysus and than the blue led stays on but only fired up for a second or so, so he tought the ysus was faulty and order a new ysus in china but made no difference
              (Seems almost the same as mine problem but mine have red leds blinking and that one not)
              • kamei10
                • Feb 2016
                • 44
                • Belgium
                Finally measured the vsus and adr and both are 210 and 71vdc, should the 71V enough ?
                Should it be still a bad ysus ?
                Another question for the pioneer fans, is the panasonic TX65VT30 as good as the pioneer 6090 ?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Hmm sounds like a mainboard ir cntrl board issue to me. Have you an rs232 wire ? If so I can guide you on how to run the test patterns on the Tv.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Also any luck with the other Kuro as well ?
                      Both those voltages are ok. Vadr would nominally be 75V, but a slightly lower figure would only cause maldischarge...not complete absence of image.
                      • kamei10
                        • Feb 2016
                        • 44
                        • Belgium
                        I have a rs232 wire but the TV is not with me, i will ask that he can deliver it here and than i will look again.
                        Haven't got the parts for order as i would like to order parts for both Kuro's at once as i need to order abroad and always pay high shipping costs for separate parts.
                        What about the panasonic TV, should it beat the kuro picture ?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Havnt seen a Panny but I would say Kuro would beat that one.
                          • ChaosLegionnaire
                            by ChaosLegionnaire
                            09-13-2022, 09:02 AM
                          • Rupsenkind
                            Yamaha RX-A1030 working, no sound output
                            by Rupsenkind
                            Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
                            Just to recap:
                            No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory...
                            07-10-2022, 03:15 AM
                          • Kartowl
                            philips 47pfl6158k/12 image faded away, sound still coming from TV
                            by Kartowl
                            Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                            04-23-2024, 12:57 AM
                          • FZG
                            EVGA Nu Audio Sound Card - Not Working
                            by FZG
                            I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                            The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                            I found...
                            03-07-2025, 11:44 AM
                          • wolf1976
                            samsung ue40d6100 has no backlight no sound and image
                            by wolf1976
                            hi to all
                            on the above model of samsung i have the faults i have told already on the title
                            iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                            any idea from someone what can i measure so i can find the problem ?
                            the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                            11-17-2024, 01:02 PM
