Yamaha RX-A1030 working, no sound output
  • Rupsenkind
    • Aug 2021
    • 26
    • Nederland
    Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
    Just to recap:
    No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory reset to get the unit to live , ok then I upgraded to the latest FW version 1.98 also ok. However I still have the same issue.
    Next steps were:
    - Swap of Funcion-1 board >> issue still there
    - Swap of operation(2), video(3) and digital(2) boards >> issue still there
    - Afyer each swap a factorty reset has been executed
    Now next step is trybing to follow audio stream with help of a scope (many tnx Budwich for all receommendations given) to determine where the issue may be.
  • budwich
    • Jul 2015
    • 3097
    Re: Yamaha RX-A1030 working, no sound output
    Hopefully, you will get to a "fixable" point (ie. replaceable component). I tried to follow the SM but my knowledge is limited. Look at page 107 dealing with the digital pcb. The "path" of the digital signal goes thru ic911 ("I see help!!!!" ... maybe it needs help... :-) ). Anyway, it needs support from main processor along with store for its work. I haven't looked further as to what they need to be happy but I am not liking this in terms of "easy repair" at least at my level.
    You might check voltage requirements in and around the area to ensure that the components are getting their electrical needs met... especially, if you have changed out boards (functional ones) and still have the same issue. That usually means the root of the problem is elsewhere (powering maybe).
    Further: page 145 shows the output of IC911 for each channel and appears to be digital which then is feed to D/A to feed amp / pre-amp sections thereafter... maybe. Might be worth try to check those areas some how. Be careful, use "temporary soldered wire aids" to access points when testing under power.
    • budwich
      • Jul 2015
      • 3097
      oops... I mis-read your initial post and "switched around the symptoms" (ie. hdmi versus analog). sorry. Relooking at things... maybe check around ic702 which takes handles the final stage of signal processing (D/A) for the channels.
      • budwich
        • Jul 2015
        • 3097
        Look at page 148 which shows some of the dealings with analog signals associated with IC701. You should be able to input an analog 1khz tone (or equivalent) via rca's in and find the signal at r/l (depending on where you input to original)... you then should be able to see if it gets switched thru ic701 and out towards the outputs via "B3 connection reference" on page 148.
        • Rupsenkind
          • Aug 2021
          • 26
          • Nederland
          Tnx Budwich, will focus on that and check voltages. I've also a suspicion that it might be the DSP chip though and coincedently same issue on 2 boards. Yesterday I had 2 RX-V673 units with identical issues, then reflowed the DSP chips and all good (for now, I know this may be a temporary solution as the TI chips D80YK113CPTP400 are known for their issues...to be continued...tnx!
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
          • jjne
            Yamaha RX V675 sound issues
            by jjne
            I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
            From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
            At first I thought it was either a speaker relay or the DSP, but I don't think...
            06-24-2025, 07:01 AM
          • AlexVG
            YAMAHA CLP-550 without of sound
            by AlexVG
            Hi.
            I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
            I have replaced all green marked elements, but it gave me nothing.
            The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
            But it is custom YAMAHA's chip, and I can't find any information about it.
            Maybe somebody came across with the same issue?
            Any information will be very useful. I will be very appreciated.
            Thank you....
            06-08-2025, 09:29 AM
          • mecha1166
            Copper corrosion? Yamaha HS8S Audio 1 output only
            by mecha1166
            OAUD Yamaha HS8S Audio one output only.
            I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
            08-04-2023, 02:55 PM
          • Jedi134
            Uniden bearcat UBC 360clt no sound output
            by Jedi134
            Hi I have inherited the above desktop scanner, all seems to work correctly but there is no sound output. The only sound I do get from the speaker is the beep confirmation when you press a key. No output from the headphone socket either. Not even radio static with squelch fully turned down, tried a reset by holding 2, 9, and hold buttons but still no sound, does anyone have any experience with these scanners, thanks.
            05-13-2024, 04:12 AM
