Re: Post The Led Backlights Your Fixing Here.
Yeah Im the opposite more Ves panels than any other brand. My dads 2009 Samsung Led Tv which im fixing (thought it was 2011) been used over 30000 hours on max brightness still works like a champ just needs a minor repair. Im doing at least one ever 3 or 4 days. Its a nightmare.
I now fix at least one per day. Mainly LG then vestel 32 inches. They are failing at an alarming rate, especially if you think the original LEDs were made never to failLeave a comment:
Got a 32" Digihome Full Hd Smart Tv with VES315-WNDS (Samsung Lcd) to fix. Two bad Leds both O/C replaced them and set workingLeave a comment:
Thread started to simply see how bigger scale these Led backlights are failing and how many you have fixed. So far I have fixed 58 of them all with one or more failed Leds stopping the backlight firing on ! How many and how often do you get Led Tv's with failed backlights ? Let me know what you have on.
I have on now:
32" Lg Led Tv 32LN5400
32" Technika Led LTA320AP33Last edited by ReeceyBurger123; 04-19-2016, 08:57 AM.Tags: None
by PipolupsHi there !
I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...10-08-2024, 11:58 AM -
by TrisHClHi,
First post...
I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
I disconnected the main board from the power... -
by max789Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
I made the following tests:
1. Disconnected the main board from Power Board = backlight works.
2. Connected the main board and disconnected the T-Con = backlights does not work.
So I ordered a main board from Ebay also BN41-02156A but from... -
by bpcannan'Morning,
I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate... -
by jesteraceHi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
However, I am in a dilemma.
I tested the backlight outputs with the lights disconnected... - Loading...
