Sony KV25fs150 with retrace lines.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I have a Sony KV25fs150 which has retrace lines no video but there is sound.
    When the television is switched on there are retrace lines with a bright screen
    and then the television shuts down and the stand by light flashes 2 times.
    The voltage supply which goes up to the CRT board is low and I have tested the
    capacitor which is on that supply line and it is ok.I have also changed the video
    amp IC on the CRT board .When I tested the supply which goes up to the CRT
    board on the A board,it is very high before the television shuts down.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KV25fs150 with retrace lines.
    Look for a problem in the Horiz Osc circuitry. Probably abad Non-polarized Hi-volt capacitor.
      I don't know a lot about CRTs but I did have this issue with a TV when the high voltage circuit was going too high - lack of feedback from the flyback or something open circuit somewhere?
      I also saw it when I adjusted the SCREEN voltage too high (although it didn't shut down, the PSU just made a rather awful noise.)
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Personally I would say you line output IC is at fault. The frame output appears to be operating since it's attempting to give you a full height picture. Also as suggested check out your capacitors in the line output stage and any EHT HV caps.
        Service manual
        http://www.manualslib.com/manual/864...page=40#manual
        • spicedrvr
          • Oct 2012
          • 8
          Check the voltages at the CRT
          R-K
          B-K
          G-K
          G1
          G2
          Then pull the CRT Board away from the Tube, and then check the voltages again. Could be a shorted Tube.
          Also, get a Sams and check the video drive voltages carefully.
          • SEAWOLF
            • Nov 2011
            • 177
            Thanks for your reply.
            • SEAWOLF
              • Nov 2011
              • 177
              R-K
              B-K
              G-K
              G1
              G2
              I have pulled the CRT board from the tube already and checked the voltages and it is not the tube.
              • fredaelsadany
                • Jan 2016
                • 66
                • EGYPT
                HI
                you must measure 180 up to 200v that supplying the 3 cathodes through 3 resiistors (10 to 15 kohm/2w) . if this voltage is low the screen will be more bright with flyback (retrace lines) because the condinser of this voltage is dry .
                it is about 10 to 22uf/250v.
                replace it all will be OK .
                THANKS
                • R_J
                  • 9623
                  On these sets its most likely the ic702, TDA6108 crt drive ic on the CA board (crt neck board), check check and see if it has +200 volts on pin 6, or check on l701 or c704 or c705. if its low its a good chance the ic is bad.
                  2 blink code os OCP on b+, If I do remember you can disconnect cn502 and see if the short goes away (you won't have picture with this plug disconnected) You can then isolate pin 6 of ic 702 if you like, or just remove the ic.
                  I bet its shorted internally
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Also too, a faulty Horiz Osc transistor may cause this issue.
                    • R_J
                      • 9623
                      If there was no horz. osc. you would get no picture at all. The horz. drive signal comes from the y/c jungle ic not a single osc. transistor.
                      This should be the same manual
                      • SEAWOLF
                        • Nov 2011
                        • 177
                        I have changed IC TDA6108 disconnected CN703 and checked all the voltages on the CRT board and they are low.I have checked the volts at the cathode of
                        D523 which is located on the A board and it is high.When I unsoldered the diode
                        the volts is 178v.Therefore it appears that there is a fault on the A BOARD.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Check electrolytics in the Power Supply...maybe a faulty 470uF 25V
                          • fredaelsadany
                            • Jan 2016
                            • 66
                            • EGYPT
                            hi
                            if KR/KG/KB are 180v you are raising the screen voltage plaese decrese the screen from line transformer (lower put) . if no effect change line transformer .
                            thanks
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              I think fredaelsadany is saying the Flyback transformer, as the lower pot is the Screen control. Yes, she might be right...look also at the Big Filter Capacitor, too.
                              • SEAWOLF
                                • Nov 2011
                                • 177
                                I have lowered the G2 control completely and the retrace lines are still present
                                and therefore I will continue to check for any faulty components on the A board.
                                • R_J
                                  • 9623
                                  You must be using a different service manual than me, do you get +200 on tp94?
                                  • SEAWOLF
                                    • Nov 2011
                                    • 177
                                    I am using the service manual for the Sony KV25fs150.
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      If checks on the Horiz Osc and Output circuitry like Hi-volt Non-polar Caps, Horz Osc and Output Transistors. Main Filter Cap and other small electrolytics in the Power Supply are OK. I would check ALL the Hi-k resistors around the F/back Transformer then I would conclude that the fault is with the F/back Transformer.
                                      • R_J
                                        • 9623
                                        I did not have that exact diagram but I think I have it now, is this the same? if it is, when you disconnect cn703 from the cv board does the voltage +200 volts come back on D523 (K) on the "A" board, and does the error go away?
                                        • kralg
                                          SONY CPD-E400P overbrightness and visible retrace lines
                                          by kralg
                                          Hi, I am trying to save my old monitor once I was so proud of. I hope there are still some people around with experience.
                                          Symptoms: overbrightness and visible retrace lines. When full white image is displayed, the monitors shuts off with flashing yellow.
                                          I have read previous threads and posts with similar issue, but none of the solutions can be applied to my monitor. According to them I need to suspect the G2 voltage as the issue.
                                          I attached the page of the A board schematic. In my case the G2 voltage supply coming from the flyback transformer is supposed...
                                          11-16-2022, 01:51 PM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • ggil44
                                          Sony XBR-65X750D Horizontal lines bottom of screen
                                          by ggil44
                                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                          05-30-2023, 07:51 PM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
