Samsung UN60F6400AF Solid Blue Line on right Hand Corner of Screen
  • sfernandes
    • Oct 2013
    • 229
    Hello guys,
    I have attached pictures of the issue. As you can see in the picture you are able to still see the menu over top of the line the line sits in the background. As you can see the menu has some graphical glitches as well. I thought this was a TCON issue since I could see the menu over top the line so I ordered a TCON from shopjimmy put it in and same issue. I have cleaned and re-seated all ribbons with no difference. If I disconnect the ribbon from the TCON on that side of the screen the line is gone, but I also don't get the menu it just stays black on that side. Anyone have any idea? Do you all think I got a faulty TCON from shopjimmy? Pictures are attached.
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung UN60F6400AF Solid Blue Line on right Hand Corner of Screen
    Could be a tab bond. Try to flex the screen in those corners to see if anything changes.
    • sfernandes
      • Oct 2013
      • 229
      I will try that, but I was always under the impression that if the menu image overlaps the line the panel is ok am i incorrect about that? please advise.
      • sfernandes
        • Oct 2013
        • 229
        Bump up
        would be nice if Tom66 could chime in on this one.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Could be mainboard--Dunno.
          Prob panel though...
          TELEFIX
          • sfernandes
            • Oct 2013
            • 229
            I'm playing with the set right now. I just updated the firmware no change. Decided to go into the service menu did a device self test. It's odd on the device self test screen it's all white and no blue bar if it was the panel would it not have the blue on that screen as well? I did the test everything says ok except for the TCON it says NG anyone know what that means? I have a screenshot attached. I also uploaded a picture that shows panel hours being 6 hours only this is a new TV do you think it already has bonding issue at 6 hours?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Mainboard is faulty. Thats a good thing though as its at least fixable
              • sfernandes
                • Oct 2013
                • 229
                Just did a factory reset from service menu. No change.
                • sfernandes
                  • Oct 2013
                  • 229
                  Yeah I suppose I could try the mainboard. Do you agree if it's a bad panel it would have the line on all screens? I also did the panel flex no change in the line
                  • sfernandes
                    • Oct 2013
                    • 229
                    I don't know about mainboard anymore I'm going threw all the tests in the service menu and I test the tcon/FRC and it says NG not ok like all the other tests and I have attached another picture that if you look closely on the TCON test screen the line is gone but lots of little lines appear on the other side of the screen
                    • sfernandes
                      • Oct 2013
                      • 229
                      well after some google research I see that NG stands for no good so the self diag test in the service menu is saying the tcon is no good. So I think shopjimmy sent me a failed tcon according to the self diag test.
                      • sfernandes
                        • Oct 2013
                        • 229
                        Well I ordered a mainboard and the set had the same issue. So I decided to look at the tab bonds and found one ribbon not seated properly on the board that runs along the bottom of the panel the board that sports the tab bonds. So I re-seated the ribbon and it fixed the issue. I attached a picture of the ribbon and of the working set the ribbon that wasn't properly seated is in the middle you could tell the white part of the ribbon is much thicker than the others telling me it wasn't seated all the way
                        • mmartell
                          • Oct 2013
                          • 3189
                          Excellent!
                            https://www.badcaps.net/forum/attach...8&d=1460675042
                            That is sure strange that you get the no bar on that picture, I would expect that bad seating cable will have affect on all modes.
                            Thanks for the follow-up on the repair.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Good work, I actually had a 39" Celcus with Ves390 Panel using Cmo glass with a similar set up. The screen would go all solarised and weird every so after. After reseating them cables issue solves. Will make video.
                              • Programmer1
                                • Dec 2020
                                If all ribbon cables are already inserted but still showing the same line you have any recommendations?
                                Also showed the same t con no good
                                • cajoeg
                                  Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                  by cajoeg
                                  Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                  The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                  02-10-2025, 04:01 PM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                  Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                  This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                  09-07-2024, 05:50 AM
                                  Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                  09-07-2024, 05:00 AM
                                  Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
