Sharp lc46le811e one flash on inverted v
  • comptek
    • Aug 2013
    • 606
    Hi guys i have a LC46LE811E and its got the single flash on the inverted v in the middle of the bezel. eg flash.......flash.......flash......flash etc
    i can force it on by (-VOL) (+CHAN) + POWER tv works fine watch tv, tune change inputs etc turn off with remote turn back on no problem, unplug tv and back to flash.......flash......flash.....
    i have done it once but for the life of me i cant get the "K" back up it has the touch panel not proper switches, what am i missing out or how long do i have to keep buttons down for ?
    i have also tried menu "9,9,9,2,2,2" but all it does is change channels
    any advise will be great
    Gary
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sharp lc46le811e one flash on inverted v
    Can you post some sharp photo's of the power supply and of the connectors with legends along side.
    • comptek
      • Aug 2013
      • 606
      Here You Are Dick
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Checked the service manual mate ? Also think one flash means backlight lamp failure.
        • budwich
          • Jul 2015
          • 3097
          you need to get into the service menu and reset the lamp error counter. How are you powering up during the sequence?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Recently someone said that the one of the pins on the pot had become detached and with soldering it back into place brought the Leds back on. Can't remember the model but I see there a pot alongside the Led connector in your photo.
            • comptek
              • Aug 2013
              • 606
              im thinking along those lines too mate but i can see any dark patches yet wanna get to screen test to check
              • comptek
                • Aug 2013
                • 606
                -VOL +chan and pwr
                • comptek
                  • Aug 2013
                  • 606
                  i will check that area again and report back thanks
                  • budwich
                    • Jul 2015
                    • 3097
                    Originally posted by comptek
                    -VOL +chan and pwr
                    I don't think that powering sequence is correct IF you are using the power button.
                    • comptek
                      • Aug 2013
                      • 606
                      ACTION The unit has detected a lamp error.
                      You can bypass the lamp error by entering the following sequence:
                       When the pyramid icon is flashing, hold down the VOL- and CH+ keys on the front touchpad.
                       Whilst holding down the keys, press the POWER ON key on the front touchpad.
                      The unit will bypass the error and the working lamps will switch on. You can then see in the panel where the fault is located.
                      • budwich
                        • Jul 2015
                        • 3097
                        yes that is the sequence for bypassing the error condition / counter. You then visually look at the set to try and "spot" a bad "lamp"... but you need the sequence to get into the service menu to reset the counter.
                        • comptek
                          • Aug 2013
                          • 606
                          yes i have looked and there are no visable patches,
                          and the problem im facing is to get the "K" up for sevice mode im holding -vol and input and its not doing anything
                          • comptek
                            • Aug 2013
                            • 606
                            Finally did it got to service mode lamp error 5
                            reset and gonna see if it clocks it up again
                            thanks guys
                            • budwich
                              • Jul 2015
                              • 3097
                              good.... I assume now that it powers up in "normal fashion". Hopefully, the counter will not go up again. As another post indicated, perhaps you have some "marginal" hardware connections which might be an issue. Perhaps recheck connector seating. Fingers crossed.
                              • comptek
                                • Aug 2013
                                • 606
                                i will i have been turning it on and off trying to see if the counter goes up
                                thanks Bud
                                • mr2tone
                                  • May 2016
                                  • 3
                                  • United Kingdom
                                  Hi, how did you get into the service menu please? I've got the exact same problem as you
                                  • comptek
                                    • Aug 2013
                                    • 606
                                    Please execute the following procedures to enter the adjustment process mode when the power supply shuts down.
                                    1) While holding down the “VOL (-)” and “INPUT” keys on the set at once, touch the power supply key on the set.
                                    Please separate the fingers from key on the set when boot-up is confirmed with lighting of a central icon etc.
                                    After a while, The letter “K” appears on the screen. This state is in Inspection mode.
                                    2) Next, hold down the “VOL (-)” and “CH ( )” keys on the set at once.
                                    Multiple lines of blue characters appearing on the screen indicate that the set is now in the adjustment Process mode.
                                    If you fail to enter the adjustment process mode (the display is the same as normal startup), retry the procedure.
                                    3) To exit the adjustment process mode after the adjustment is done, unplug the AC power cord to force off the power.
                                    (When the power is turned off with the remote controler, once unplug the AC power cord and plug it in again. In this case, wait for 10 seconds or so after unplugging.)
                                    • mr2tone
                                      • May 2016
                                      • 3
                                      • United Kingdom
                                      Doesn't work because I need to unplug the set in order for the “VOL (-)” and “INPUT” sequence to work, but as soon as I plug the set back in the central icon starts flashing again
                                      • comptek
                                        • Aug 2013
                                        • 606
                                        with it plugged in and flashing hold the power button (touchpad on the front) light should go out after a while then do vol- and input
                                        • ekozeko333
                                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                          by ekozeko333
                                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                          🔥 The Problem Started After Suspected ESD/PD Fault
                                          I experienced a power issue or ESD event through a USB-C charger
                                          After that, the NX20P5090 power switch was visibly burned and was replaced
                                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • yucel-yucel
                                          Sharp LC-39LE652V Nand Flash
                                          by yucel-yucel
                                          Sharp LC-39LE652V model device could not be opened due to nand software error, we rewrote the nand software and it worked. But we were able to find the software without satellite, it does not see the internal satellite. Does this model have a working satellite version and software? Thanks in advance.
                                          Model ; Sharp LC-39LE652V
                                          Panel ; V390HK1-LE6
                                          Mainboard ; QPWBXG135WJZZ
                                          04-06-2023, 04:57 AM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
