Vizio SV472XVT won't turn on
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Vizio SV472XVT won't turn on
    I can access shopjimmy from the UK by using an IP address changing program.
    So it does look like the main board.
    • Joseph cauchi
      jccomputers
      • Jan 2015
      • 89
      • Malta
      Budm when you have a link of shopjimmy and I click it will ive me Access denied
      • cmitchel
        • 14
        So it sounds like the only thing I can do now is replace the main board. Once a new one is installed, will this fix the 24V going to inverter board and 18V/12V going to main board? I don't have a wiring diagram for any of these boards to see if those power circuits are passed through relays that need a switching circuit from the main board.
        • CapLeaker
          Leaking Member
          • 8146
          if you have STBY voltage but no PSon once you try to turn on the TV = You need a new main board.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Did you solve the problem?
            • cmitchel
              • 14
              Yes I did! After the new power supply board didn't fix it, I ordered a new main board for it. Just swapped that out last night and it's working like a champ! Now I just need to verify the VGA input is working properly as it didn't pop up as a 3rd PC monitor, but that should just be a computer setting. I also noticed some horizontal lines appearing for a fraction of a second on fast motion or quick screen jumps. I believe it is just a de-interlacing issue with the 240hz smooth motion settings, so I'll just keep those turned off.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                That's good new.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  Yesterday, 08:34 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                  by JDC
                  ONN 100012588
                  Issue: No Power, Then Rebooting After Main Board Change
                  Short answer: replace main board and power board
                  Technical answer: replace main board and Q306 & Q307 on power board.
                  Long answer:
                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                  07-15-2022, 07:39 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
