Vizio SV472XVT won't turn on
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Vizio SV472XVT won't turn on
    I can access shopjimmy from the UK by using an IP address changing program.
    So it does look like the main board.
    • Joseph cauchi
      jccomputers
      • Jan 2015
      • 89
      • Malta
      Budm when you have a link of shopjimmy and I click it will ive me Access denied
      • cmitchel
        • Dec 2014
        • 14
        So it sounds like the only thing I can do now is replace the main board. Once a new one is installed, will this fix the 24V going to inverter board and 18V/12V going to main board? I don't have a wiring diagram for any of these boards to see if those power circuits are passed through relays that need a switching circuit from the main board.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8119
          if you have STBY voltage but no PSon once you try to turn on the TV = You need a new main board.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Did you solve the problem?
            • cmitchel
              • Dec 2014
              • 14
              Yes I did! After the new power supply board didn't fix it, I ordered a new main board for it. Just swapped that out last night and it's working like a champ! Now I just need to verify the VGA input is working properly as it didn't pop up as a 3rd PC monitor, but that should just be a computer setting. I also noticed some horizontal lines appearing for a fraction of a second on fast motion or quick screen jumps. I believe it is just a de-interlacing issue with the 240hz smooth motion settings, so I'll just keep those turned off.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                That's good new.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  by JDC
                  ONN 100012588
                  Long answer:
                  07-15-2022, 07:39 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
