LG RZ32LZ55 - Interlacing Problem!!!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    This one has me stumped.
    The TV is quite a few years old and appears to show what I can only describe as very feint interlacing lines across the screen at about a 10 - 15 degree upward slope L to R.
    The problem is that I am unable to photograph them because they don't show up on a photo. I've filmed the screen and when looking carefully at the video the lines are visible, however when converting it from MOV to MP4 to upload to Youtube the interlaced lines are no longer noticeable.
    I've inputted signals via the Scarts and also from my PC and the "interlacing" is present regardless of input.
    In all other respects the set works fine.
    Your thoughts would be welcome.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG RZ32LZ55 - Interlacing Problem!!!
    I repaired quite a few of these weight a tonne for 32" dont they ! Maybe a service menu reset if you have a service remote ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Hello ReecyBurger123
      I can get into the service menu but nowhere can I find a reset.
      Getting into the Menu by holding the Menu button on the TV until the Service Menu comes up and can get into a second menu if you then press the remote menu button. Unfortunately I cannot see on either menu an option to reset the set.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        If anyone knows a method of getting into the service mode if there is one I would appreciate it. Thanks
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Hi ive downloaded and looked in the service manual theres not much info about a factory reset option maybe im missing it?
          • comptek
            • Aug 2013
            • 606
            • uk
            https://www.badcaps.net/forum/showthread.php?t=28273
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Thanks to vinceroger69 & comptek for your replies. Appreciated. Will take a closer look later.
              Unfortunately although I can go into the menu as budm describes there is no reset option available.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Maybe first time install in the normal Tv menu ?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Funnily enough I don't think I've even seen that. I'll go looking. Thanks.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    No worries, also was you using a service remote or just the normal one buddy ?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      page 14 of the service manual may have some usefull information regarding diffrent menus
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        I'm using the original remote for the set.
                        Edit
                        Or so I thought . The remote is not the one shown on Page 14 as suggested to check out by vinceroger69
                        The remote is an LG 6710T00008b
                        Need to do some further investigating
                        Further Edit
                        The one shown on page 14 is called the "Secret Remote" or formally the LG Adjust Remocon Service Remote
                          LCD LED TV Service Menu Codes
                          TCL LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          10-31-2024, 03:58 AM
                        • Chrissygizmo
                          Sony KD-55XG9505 lines on screen problem
                          by Chrissygizmo
                          Hello again everyone,
                          This is my latest mission, to try getting this Sony tv back to normal working order…
                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                          02-19-2025, 11:31 AM
                        • DrvLikHell
                          Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                          by DrvLikHell
                          Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                          The...
                          02-05-2025, 01:44 AM
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • joelz
                          pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
                          by joelz
                          Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
                          11-18-2024, 06:02 AM
