LG rz-32lz55 lcd tv faulty image
  • anno
    • Sep 2007
    • 140
    • netherlands
    Hi
    i have a lg 32 inch lcd tv with a faulty image. only 1/8 part of the screen is displaying a picture. The menu is displayed correct? I have no idea where of what to look for. anyone can help?
  • twbranch
    Mad Nerd
    • Oct 2012
    • 153
    Re: LG rz-32lz55 lcd tv faulty image
    I think you have a connection loose on the video board. Check the connections on your circuit boards. If that doesn't work there should be someone here in a bit with a little more experience with this problem.
      I would recommend a service reset.
      MENU on TV and MENU on remote control (hold both for up to 10 seconds), then select RESET option.
      • twbranch
        Mad Nerd
        • Oct 2012
        • 153
        Does that fix this problem? I had a similar and reseated a cable and fixed it. Does the reseat do the same as a reset?
          I have no idea. I'm just recommending it.
          And unless the TV has a bionic cable-reseating arm, I don't see how anything you do in the service menu will be able to reseat a cable.
          I'd be surprised if it was a loose cable, unless this TV has two separate main boards perhaps only one for analog and one for digital like HDMI and DTV, I have seen an older LG LCD which did that. Things like LVDS aren't going to cause this.
          • twbranch
            Mad Nerd
            • Oct 2012
            • 153
            HAHA! I guess what I was saying was...can reseating a particular cable reset the tv in some way? I can't recall if I tried a reset on the one I had a few years ago. But the reseat fixed a similar problem to this! Thanks!
              I doubt it, there may be a few exceptions.
              • anno
                • Sep 2007
                • 140
                • netherlands
                ok thanks, but i don`t see a reset option in the service menu
                  Can we see an image of the service menu -- it may be buried away.
                  • anno
                    • Sep 2007
                    • 140
                    • netherlands
                    there is another problem now. it won`t come out of standby. the voltages from psu are okay i think. I measured some voltages on mainboard : VCTI_ST_1.8 , ST-5v , st-3.3v are there. I am not sure this are all the voltages i should have. The rest are generated when turning tv on?
                    i made some screenshots from the service manual
                    dc-dc converter
                    i have st_5v so ic1300 is working. ic1301 and ic1101 are 'turned on' after the pwr_onoff_1 signal comes, right? I measured the pwr_onoff_1 signal and it's not coming
                    vcti voltage regulator
                    i measured vcti_st1-1.8v and st-3.3v , ic2 and ic4007 no voltages at IN pin, the 5v_b is switched by ic1101 (FET). but this fet is not driven i think (only when onoff singal comes)
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      I think that points to some problem with the main control/processing ic. I would say to get a new mainboard, but tom66 or budm will have a better opinion for sure.
                      Muh-soggy-knee
                      • anno
                        • Sep 2007
                        • 140
                        • netherlands
                        i made a picture of the service menu, maybe someone know where the reset option is. can i conclude the TCON and panel are working ok, because i get a working menu on the screen?
                        when i heat the mainboard the tv is turning on after pressing on key. i found several smd caps with high esr. could this be related to the faulty picture?
                          What's under NVM Edit?
                          T-con and panel are working.
                          • anno
                            • Sep 2007
                            • 140
                            • netherlands
                            i can't acces that
                              Have you tried using the arrow buttons or channel up/down buttons to navigate the menu?
                              • anno
                                • Sep 2007
                                • 140
                                • netherlands
                                yes on remote and tv. other items i can get in with arrow key to right on remote
                                i found out when pressing menu button again i come in 'hotel mode operation' menu. but i don`t see a reset option there
                                  LCD LED TV Service Menu Codes
                                  ALL LCD LED TV SERVICE MENU CODES
                                  Service Menu Code with Board Name
                                  China Universal Board / Jumper Board Service Menu Code
                                  Changhong Ruba Service Menu Code
                                  Ecostar LED TV Service Menu Code
                                  Orient LED TV Service Menu Code
                                  Haier LED TV Service Menu Code
                                  TCL LED TV Service Menu Code
                                  Samsung LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  Videocon LED TV Service Menu Code
                                  Supra LED TV Service Menu Code
                                  Toshiba LED TV Service Menu Code
                                  Symphony LED TV Service Menu Code
                                  Veste/ LED TV Service Menu Code...
                                  10-31-2024, 03:58 AM
                                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-12-2024, 02:20 PM
                                • mickadoum
                                  Is is possible to fix this screen ? - Grandin - UD58LGB204
                                  by mickadoum
                                  Issue with TV Display – Vertical Color Stripes on One Side (T-con board replaced, no improvement) - Grandin - UD58LGB204
                                  I'm experiencing an issue with my TV, and I would appreciate any insights or suggestions. Here's a description of the problem:
                                  • The TV shows vertical multicolored stripes on the left side of the screen, covering around 30-40% of the display.
                                  • The right side of the screen shows the image normally, although sometimes slightly distorted depending on the content.
                                  • The issue persists whether I'm displaying the TV menu or any other source,
                                  10-02-2024, 01:16 PM
                                  HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                  09-06-2024, 10:56 AM
                                  HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
