VESTEL LED BACKLIGHT - repair/replace options ?
  • davewtv
    • Jan 2016
    • 6
    Ok, I have what is most probably the standard problem with these 'beasties'.. namely "Xmas tree wiring" - in other words their dire "one out all out" (series) arrangement !
    I am looking at a couple of options to resolve the problem and would appreciate some input as I am sure this has been done before by others on here.....
    First question is if I replace the faulty LED on its own (after I have removed the 'mushroom' diffuser) just what type/s of SMD LED would you recommend ? (I assume here it is a 12V LED being over-driven but have no idea of the rest of the spec.) Comments/advice appreciated therefore !
    Second question is has anyone re-jigged their panel to some other kind of illumination (for instance 5050 led strips horizontally with a separate PSU or some such) ?
  • Diah
    • Feb 2013
    • 6438
    Re: VESTEL LED BACKLIGHT - repair/replace options ?
    answer 1 : its 3528 Forward Current:400mA Forward Voltage:3.05-3.65V, take look here https://www.badcaps.net/forum/showpo...95&postcount=1
    2- i don't tried this, because its unreality solution.
    • davewtv
      • Jan 2016
      • 6
      Thanks Diah, very helpful; Have ordered some of these and will report back ! -
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        They will work but they are 1w which is too bright snd the light gain wont be even. Best to do the stacking method of repair if you have ever heard of that ?
        • davewtv
          • Jan 2016
          • 6
          Thanks RB123 - but I plan to glue the mushroom on top, too ! If 1W is too much what is the correct value ?
          Yes, I noticed the "stacking" method, but again this means trashing a whole LED strip rather than just replacing a LED itself.....
          It is always annoying, at least to me, when in this "modular" world we have to pay (say) 10 dollars to replace a 10 cent item that failed
          (but that could easily be replaced individually)
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • unimatrix93
            Which resistor should I remove/replace to decrease current to backlight leds?
            by unimatrix93
            Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
            However I need some help identifying the resistor I need to replace to achieve this.
            Thank you!
            11-29-2024, 05:05 AM
          • Raulnn
            Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
            by Raulnn
            Hello! I am new to electronics, and this forum is fantastic. I have the following problem, I have an Ansonic 32HD1 tv, a generic brand from Vestel, with a 17IPS11-R4 power supply and main 17mb55.
            The tv has no backlight, but it also has no image and sound. when it turns on the standby light blinks several times, and there is a very short flash of the backlight, as if it wanted to start, but it does not start. I have measured the voltage on the red wire of the backlight, as you have seen on the forum, and in standby it has 30v, and when it turns on it goes up to 100v and slowly drops...
            11-15-2022, 03:02 PM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
