coby TFTV4025 POWER SUPPLY 24V NOT PRESENT
  • hmendez86
    • Jun 2015
    • 344
    • united states
    I got this coby tv tftv4025.....it powers on blue ligth and no image even with looking with a flash light.....power supply give 5v only...I jump stbv to 5v and no 24v and no 12v......check for short transistor and caps and they seem good..I removed power to take a look and nothing seem burn like I said test transistor and they are good am just in ?? About the ones that are behind the caps were it connects the 24v to the inverter. They read .145 something like that and .3
    They are 3 transistors
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: coby TFTV4025 POWER SUPPLY 24V NOT PRESENT
    I'll post pics later on the day...
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      What inverter does it use ?
      • hmendez86
        • Jun 2015
        • 344
        • united states
        inverter
        • hmendez86
          • Jun 2015
          • 344
          • united states
          I marked 2 blck lines on the stby voltage that's were I jump to self start power.....and it just give me 5v and 0 on 12v and 24v...
            Is this the your board? Please loo at the numbers as printed on the barcode sticker.
            Coby MLT668TL-G Power Supply for TFTV4025
            http://www.shopjimmy.com/coby-mlt668...pply-unit.htm#
            Do you have about 400vdc between the two legs of the main filter cap when you force on the power supply?
            Do you get the 24V if the inverter board is not connected to the power supply board?
            • hmendez86
              • Jun 2015
              • 344
              • united states
              I don't get 24v on the power supply=this is by the inverted be disconnected
              • hmendez86
                • Jun 2015
                • 344
                • united states
                I don't get the 24v and 12v on power supply......I just got 5v stand by....it just give the voltage to turn on the power once I do that nothing goes up like the 24v or 12v
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  MLT668TL-v
                    Next you need to find out if you do have the 400VDC between the two legs of the main filter cap or not because the 24V PS needs that boosted Voltage to run.
                    • hmendez86
                      • Jun 2015
                      • 344
                      • united states
                      It is a 450v 120uf the big cap that's were u point to it......I replace it with a 450v and 150uf and same thing
                        Again, We need the DCV readings between the two legs to find out if you have PFC Voltage boosted Voltage or not.
                        • hmendez86
                          • Jun 2015
                          • 344
                          • united states
                          One led -1.344 dcv second leg 8.45dcv... am I right how I tested or need to put probes to both legs at DC voltage...
                            We want to measure the DCV between the two legs of the cap, red probe on the positive leg, Black probe on the negative leg.
                            • hmendez86
                              • Jun 2015
                              • 344
                              • united states
                              Ok 347 dcv
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Is that with the Tv on ?
                                • CapLeaker
                                  Leaking Member
                                  • 8146
                                  kinda low for boosted voltage. The TV has to be on... other than that he would only get rectified mains at 170VDC.
                                  • hmendez86
                                    • Jun 2015
                                    • 344
                                    • united states
                                    I jump start the power with the stanby voltage
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      Cap leaker)) so that's means ??? So 347dcv should be ??? And what is causing this problem.......rectifier, resistor, or cap
                                        What is the P/N as printed on top of the IC1?
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
