toshiba 32d1333db. No Backlight
  • Mouseyrain
    • Mar 2016
    • 6
    • Scotland
    Hi, I picked up a toshiba 32d1333db with broken backlight for cheap so I thought I would try and fix it
    I have completely opened up the TV but don't know how to test the LED's
    It uses "veS315WNDL-01" Led strips
    if anyone could help me work out how to test these LED's with my multimeter that would be really helpful
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: toshiba 32d1333db. No Backlight
    Ahh more classic Vestel Led trash failing. Watch my youtube video on the same Ves315 screen hope it helps:
    https://m.youtube.com/watch?v=RxwdC7V5Ue0
    • Mouseyrain
      • Mar 2016
      • 6
      • Scotland
      Ah thanks will check this out
      • Mouseyrain
        • Mar 2016
        • 6
        • Scotland
        Well. I'm pretty sure my Multimeter is broken. So will borrow someones and try this tomorrow. Thank you. Wish I found this sooner!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          No worries, keep us updated on what you do
          • Mouseyrain
            • Mar 2016
            • 6
            • Scotland
            Right. I got the multimeter.
            I have set it in diode mode and when I check the LED's the multimeter beeps BUT the LED does not come on. I have tried on almost every LED and the same thing has happened everytime. Does this mean I have to replace the LED strips or am I just doing something wrong?
            • Mouseyrain
              • Mar 2016
              • 6
              • Scotland
              Oh. Wait I don't know what i've done but I was able to light up an LED
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Your testing them wrong, you need to put positive on the dead shorted strip then negative on the start of the next Led.
                • acman
                  • May 2016
                  Hi thanks to Rb 123, I have got one of these 32" Toshiba 32W1333DB, failed backlight syndrome, assuming that the power supply had failed was about to buy another psu, a strip down has revealed that it's a failed led, only one though. Going to attempt a repair, probably the 'stack' method.
                  Any one know who supplies one?
                  Many thanks to Rb again.
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    Me ebay item number 262430603052
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Thanks for the feedback glad to help Also Flocko does lol if not look on ebay for smashed Led Tv and you can get alot of strips from one set
                      • acman
                        • May 2016
                        Hi Flocko, looking on the leds on ebay, I think they look like set 'D' type, will check later,
                        the tv as in the title is a Toshiba 32D133DB, the led strips have vestel on them.
                        Regards, acman.
                        • flocko
                          • Nov 2012
                          • 1121
                          • uk
                          most Vestel re-badge sets are fitted with this type LED+lens (type D) some later ones are fitted with the smaller type LG Innotek I will be adding these to my listing. i already list the LG larger type (type C) and A+B type are common to Samsung and sets that use Samsung panels
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            On Vestels the model of the Panel is a dead give away. VES315WNDL the D means the type of Led used, but also this is stated on the Led strips.
                            • buchman
                              Toshiba 40L2400VQ No backlight but LEDs are fine
                              by buchman
                              I have a Toshiba LED tv model number 40L2400VQ.
                              I don't receive the correct voltage at the output to the LEDs.
                              I disassembled the front panel and checked all leds and they are fine. Then I checked the voltage to the leds on the power board and it flactuate in milivolts.
                              Tested all caps with esr meter and they are fine.
                              The diodes are fine and the resistors too.
                              Where should I concentrate on?
                              Thanks in advance....
                              03-13-2021, 12:43 PM
                            • triplefour
                              by triplefour
                              09-13-2023, 10:43 PM
                            • hollox123
                              ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                              by hollox123
                              Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                              1. Laptop keyboard doesn't work
                              2. The backlight on the laptop keyboard doesn't work
                              3. The x2 side LEDs (red) on the laptop don't work
                              The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                              I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                              But I am strongly aiming that it is somehow a BIOS-related problem,...
                              05-11-2025, 08:05 AM
                            • signal.quest
                              Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                              by signal.quest
                              I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                              03-17-2024, 10:14 AM
                            • Boyxba
                              TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                              by Boyxba
                              I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                              05-13-2023, 11:47 AM
