un46d7000lf with vertical lines
  • djpat1974
    • Nov 2014
    • 65
    • united states
    Hi to all i have and un46d7000lf TV with vertical lines even when you apply pressure to the tabs the vertical lines do not move i measure the volts on the power board and they are all normal range this is a puzzle any help will do thanks again.
  • mmartell
    • Oct 2013
    • 3189
    Re: un46d7000lf with vertical lines
    Panel failure. If pressure on the tabs doesn't help then you are out of luck. Btw I have this same tv, very nice picture.
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
    • gpo23
      Sony KDL-40V3000 - Vertical lines
      by gpo23
      i order a t-con because i had bad colors on my SONY KDL-40V3000 :
      With the new t-con the color are good but there are vertical lines on all the screen :
      I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
      Is there a way to fix the vertical lines on the new t-con ?
      Thank you for your help
      gpo23...
      10-04-2023, 09:11 AM
    • Firentiosi
      1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
      by Firentiosi
      Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
      The issues are as follows: the...
      11-27-2024, 12:33 AM
    • viking509
      vizio e65 e3 LED tv color vertical lines center tv only
      by viking509
      I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
      03-21-2023, 12:48 AM
