Philips 42PF9831D/10 Problem
  • juni0r123
    • Sep 2015
    I have an annoying problem with a philips 42PF9831D/10 which I just don't have enough knowledge to solve.
    Some of the time the TV functions just fine.
    But more & more often the TV switches off & goes into protection mode
    The red led on the front shows one long flash & 4 short.
    I know this is a problem with the SSB board as I have another set exactly the same.
    I repaired the power supply on the other one & it's working just fine.
    If I swap the SSB from the semi working one to the good one, I get exactly the same problem.
    One thing I've noticed purely by chance is, if I leave the coax aerial out
    then the TV seems to behave normally,
    but if I plug the coax in whilst on, most times it trips straight away.
    If the cable is already in, then it mostly trips just as the channel is about to appear, but not every time.
    It's 100% not the cable as this works fine with other TV's.
    I've tried to source another SSB for this tv but this is proving impossible as it's an old set & there don't seem to be many around.
    Just my luck as I really like the 4 ambilight setup on these.
    The SSB board is a bit more complex than the usual PSU repairs I've done.
    so any advice would be greatly appreciated.
    Thanks for taking the time to read this
    John
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Philips 42PF9831D/10 Problem
    Can you use your voltmeter and see if there's a voltage between the aerial coax and the tuner earth which may be causing the problem.
    • tn245
      • Oct 2013
      • 530
      One long flash and four short according to the service manual = Audio error
      Error 14 (Audio protection). The detection is done on the
      audio board itself. Several items are monitored:
      overvoltage, overcurrent, DC level on the speakers and the
      audio supply voltages. If one of these items fails, the
      audioprotection will switch off the main supply. All supplies
      will drop, the standby processor “thinks” there is a mains
      dip, and will reboot. At the beginning of the boot process,
      the audio-protection line is monitored : if this line is “active”,
      the set will go to protection and will blink error 14.
        Easy to check for DC on the speaker terminals since it is easy to get access to. I have SONY TV with the same audio protection scheme, it has failed Class D amp with DC showing on the speaker terminals.
        • juni0r123
          • Sep 2015
          Thanks for all the feedback & things to check, really appreciated.
          Another quick question though,
          How can I check the voltage at the speakers if the TV trips straight into protection mode?
          The same applies to checking between the tuner earth & coax?
          I didn't have a lot of time to check things to day, but I did try the following.
          I turned the TV on with no aerial connected & again it turns on fine.
          I then switched to HDMI & plugged the aerial in.
          The TV continued working, but as soon as I switch it over to TV it fails.
          I also tried setting the volume to 0 but in TV mode it still goes into protection.
          Regards
          John
            You hook up the meter probes (set meter to DCV) to the speakers terminals, then plug TV into the outlet and then turn on the TV while looking at the meter display.
              BTW, look at the model number label to see if your TV chassis is
              FJ3.0ELA
              • juni0r123
                • Sep 2015
                The way I worded that probably made me sound more of an idiot than I am.
                It's not how to measure DCV it was if the set's not starting would it affect the reading.
                but I guess I'll see a voltage spike as it trips.
                If time permits, will try this tomorrow & report back
                & yes the chassis is PJ3.0E LA
                Regards
                John
                  The set power switch is activated, the circuit will start first and then if it detects the fault then it goes into shutdown, yes, it is going to happen fast and your meter may have fast response time to show the fault.
                  Otherwise you will have to dig deep and narrow down to which fault causes the shutdown.
                  Post #3:
                  • janos6662000
                    Philips 47PFS7509/12 LCD TV problem
                    by janos6662000
                    Hi
                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                    I downloaded original firmware and applied the update, but the problem remained.
                    From a colleague i received a "factory package software" which is a lot bigger.
                    I made another firmware update, but still did not solve the problem.
                    Somewhere on the way the error got worse, because at the moment the...
                    08-12-2025, 12:54 PM
                  • courtcircuit
                    Philips HTS8000 home cinema noise problem
                    by courtcircuit
                    Hello
                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                    Removed each of tyhe boards
                    02-08-2025, 08:22 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • bohaboha
                    PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                    by bohaboha
                    Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                    how to fix it thanks
                    02-05-2025, 09:23 PM
                  • atkallu
                    Philips 58PUS8545 t-con problem or something else ?
                    by atkallu
                    Hello
                    I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                    See the attached image.
                    I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                    But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                    T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                    01-13-2025, 11:23 AM
