Lg 55lm5800uc 3d led tv no power blinking led
  • braxton
    • Nov 2009
    • 146
    I picked up this 3D 2012 model TV and previous owner said it just turned off while watching tv.
    When the power button is pressed, the red LED flashes slowly 2 times and then goes out. No relay clicks or any other signs of life. There is not much info online about this problem. Based on the fact that main boards for this model are very expensive and hard to find (and there are sites offering main board repair service for $200 for this model), my guess is the main board is the problem.
    Does anybody have any experience with this model and have any suggestions as to what to check on the main board?
    Re: Lg 55lm5800uc 3d led tv no power blinking led
    You can start by uploading good clear pictures so we can see all the boards and how all the boards are connected together, then you will need to do good visual inspection and then Voltage checking at the connectors.
    • braxton
      • Nov 2009
      • 146
      Here are pics of the main board and power supply already removed.
      There is 3.5V standby on the power supply but that's about as far as it gets...
      Visual inspection does not reveal any burns or bulging caps.
      • braxton
        • Nov 2009
        • 146
        this is hopefully a clearer pic of the main board
          If the PWR-ON pin on connector P201 the the main board is not sending the PS-ON to turn on the main power supply and since you also indicated all other pins are showing 0V but you do have 3.5VSTBY Voltage then it points to the main board.
          Did you try disconnected all other boards to the main board but still have the Power board and the Power button board connected to see what happen?
          • braxton
            • Nov 2009
            • 146
            Yes, with the T-con and speaker cables disconnected from the main board (and also tried LED cables disconnected from the power supply), the result is the same.
            • Diah
              • Feb 2013
              • 6374
              here the SM . follow the 3.5 volts on main board page 16
              • braxton
                • Nov 2009
                • 146
                Thanks! I will follow up when I get a chance to further diagnose...
                • braxton
                  • Nov 2009
                  • 146
                  Just to follow up. The troubleshooting process, by following the service manual, suggested the power board was the likely culprit. This was not what I initially expected. I began searches using the power board number and discovered that a ceramic cap C603 and diode D607 often get shorted. Sure enough these two components were shorted on my board.
                  Awaiting arrival of new components from Digikey to do further testing...
                    That is why were you sure that you do not have the PS-ON signal since you do have the STBY Voltage, the C603, D607 are part of the PFC Voltage booster circuit, when those parts failed you will not have boosted Voltage for the main SMP power supply section.
                    • braxton
                      • Nov 2009
                      • 146
                      Success!
                      To quote Mike Mallo on youtube:
                      A search of the part # of this board "EAY62512801", will bring up a schematic of "Revision 2" of this board. The only change is D607 is upgraded from the mentioned 4 amp diode MUR460AG, to a 10 amp rated diode. Part number of the new diode is STTH10LCD06FP. I've replaced mine with the new part, and it works well now. It is a different style package, a TO-220 instead of the axial type. So it took a little creative soldering to get it to fit on the Revision 1 board. Also it has to be kept below the maximum component height of 15.5 mm. One leg through the board, and a short jumper to the other leg works well.
                      So I installed the upgraded 10A diode component and also upgraded the cap from 200pF 1KV to 200pF 2KV and the TV works well!
                      I've attched a pic of the board with new components.
                      • cody2016
                        • May 2016
                        • U.S.A
                        Hi I am having the same problem, my C603 is burnt out. I saw that you said you upgraded that as well. did you mean 220pF 2kV? or did you change it to a 200pF? Is there anyway that you could let me know what the part number was for the capacitor that you bought from digikey?
                        Thank You
                        • iDIYit
                          • Feb 2017
                          Thank You
                          For anyone who finds this thread like I did, this repair worked for me. I upgraded the D607 diode (P/N: STTH10LCD06FP), and used a 220pF 1KV capacitor at C603 (P/N: C322C221JDG5TA).
                          • JDC
                            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                            by JDC
                            ONN 100012588
                            Issue: No Power, Then Rebooting After Main Board Change
                            Short answer: replace main board and power board
                            Technical answer: replace main board and Q306 & Q307 on power board.
                            Long answer:
                            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                            07-15-2022, 07:39 AM
                          • justice171
                            Help Needed with LG TV Power Board Repair (Model No: OLED 55EG9A7V, Board No: LGP55B7-170P)
                            by justice171
                            I'm currently troubleshooting an issue with my LG TV (Model No: OLED 55EG9A7V, Power Board No: LGP55B7-170P) and would appreciate your guidance.
                            When I press the power button, the standby LED flickers three times, and the relay clicks multiple times before stopping. During this time, I measured the voltages:
                            • Over P201: I receive all the correct voltages.
                            • Over P202: I only receive 12V, but the 24V is missing.
                            The 24V is used to power the display board (Tcon) via the flex cable, but even when I disconnect the flex cable, the 24V is still not present....
                            09-24-2024, 12:36 AM
                          • maxim2511
                            LG 55EC930V OLED - swich on swich of no screen
                            by maxim2511
                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                            Then I get an idea to take it apart and clean boards from dust.
                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                            05-14-2021, 02:21 AM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
