Light Solarization on Faces on Samsung TV
  • james030
    • Mar 2016
    • 5
    • US
    Hello hopefully some of you can help or guide me...
    My Samsung LN40A530P tv randomly colorized faces and light colors when I was watching a movie. After some online researching I think its solarization even though mine is not as bad as most ive seen. My menus all seem fine and most colors are fine even though some get extremely dark
    I have accessed the service menu and changed the option byte lvds setting as someone suggested and it made it worse so I reverted back. Now I belive it is the tcon board however I have no idea as I have never had problems with tvs before.
    If anyone could guide me I would greatly appreciate it
  • sordids999
    • May 2013
    • 2154
    Re: Light Solarization on Faces on Samsung TV
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • CapLeaker
      Leaking Member
      • 8190
      post a good hi res picture of the Tcon board. See if there is a AS-15 chip on it.
        Screen shot of the images on the screen also.
        • james030
          • Mar 2016
          • 5
          • US
          Thanks for the quick replies, attached are pictures. thanks again
            It looks like it has slightly off Gamma Voltages, I see AS15/or AS19 GAMMA Vref IC on that T-con board.
            You can test the GAMMA dcV on those GAMMA testpoints on the board.
            • CapLeaker
              Leaking Member
              • 8190
              I think it's a AS19, picture isn't that clear.
              • james030
                • Mar 2016
                • 5
                • US
                Sorry about the bad pic, Yes it does say AS19
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  It looks like a replacement Tcon is required. Can you or do you know anyone who could replace the AS19 IC. If you order a replacement you need to match up the numbers shown in the photo.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    You can also use a V400H1-C01 board in that TV. The AS19 chip is much more difficult to swap than the AS15. It has a ground plate / heat sink on the bottom that is soldered to the board. I consider myself quite good with swapping small surface mount chips and getting one of these back on straight is beyond my skill lever for sure. And that's with a nice $350 hot air rework station.
                    • james030
                      • Mar 2016
                      • 5
                      • US
                      Changed the tcon board as changing the chip would have been impossible for me and this worked.
                      Thanks to all
                        Thanks for the follow-up.
                          09-07-2024, 05:50 AM
                        • Kaar3l
                          Samsung QLED QE65Q7FNAT only standby light
                          by Kaar3l
                          TV: Samsung QLED QE65Q7FNAT
                          PSU: BN4400940A
                          MB: BN94-12832K
                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                          09-24-2024, 01:35 PM
                        • marcinq
                          Samsung UE60KS7000 No Standby Light
                          by marcinq
                          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                          05-26-2025, 11:36 AM
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • DXseekerMO
                          Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                          by DXseekerMO
                          Hello everyone!
                          Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                          Symptoms:
                          1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                          2) TV does not appear to turn on
                          3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                          4) "Power on" terminal on Power Supply has 3.26v
                          5) "A13V" terminals have 12.9v
                          6) Stand-by test jumper on Power Supply has 12.9V
                          7) Optical audio jack on Main Board illuminates
                          8) With stand-by...
                          06-09-2021, 12:19 AM
