Mitsubishi LT-52148 LCD - white picture with lines
  • caphair
    • Nov 2011
    • 1249
    This happened out of no where. Wondering if it's a panel issue? Before I dive in and take it apart
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Mitsubishi LT-52148 LCD - white picture with lines
    Hmm possibly mainboard fault here. Take it apart and get some images
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Do you have IR control and sound?
      • caphair
        • Nov 2011
        • 1249
        It does have sound, no remote for it to tell
        • CapLeaker
          Leaking Member
          • 8352
          check the LVDS with an oscilloscope and turn the menu on and off all the time. If you see changes on your scope, it's not the main board.
          • caphair
            • Nov 2011
            • 1249
            Don't have an oscilloscope but it only shows a distorted picture with an input. The menu displays crystal clear even volume, input source etc. Would that mean it's a tcon issue or?
            • caphair
              • Nov 2011
              • 1249
              Ok this has a "system reset" button so I tried pressing it to see what would happen and now it's displaying a picture normal.
              What's up with that? It does have some random lines going down as shown in that pic. Not sure if that indicates a panel fault?
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • thstuff
                SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                by thstuff
                This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                01-30-2023, 05:01 PM
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
              • adamp91gvm
                hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
                by adamp91gvm
                as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
                09-10-2025, 12:13 PM
              • hendue
                BenQ 2765HT vertical lines, no picture
                by hendue
                I was trying to fix the monitor, which was giving me the following pictures:
                It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
                I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
                Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
                I turned around...
                09-09-2025, 08:27 AM
