Sharp LC-70LE650U Will not turn on
  • Ngray27
    • Feb 2016
    • 10
    Hey Gang,
    I bought this one second hand but I am now thinking I got a dud. I've got an error code of 2 slow then 5 fast blinking lights on the stand by. I've checked to see if the main board is getting 5 volts and that checks out. I unplugged the tcon board and it now powers up. However if this is the case i've heard I may have a bad panel and not a bad tcon board? Any help in troubleshooting would be greatly appreciated.
    Cheers.
    Re: Sharp LC-70LE650U Will not turn on
    Just do the search for your model and you will see the threads.
    For example:
    https://www.badcaps.net/forum/showth...rp+LC-70LE650U
    The panel is also know for have bad side tab driver failure:
    https://www.badcaps.net/forum/showth...os+LC-70LE650U
    • Ngray27
      • Feb 2016
      • 10
      Yeah I did check those but they didn't seem to line up with my issue. However I was able to determine that it was a panel fault. Thanks for the response.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Hey,if your not gonna fix it or part it out,can i have it,or buy it(as long as you don't bust the screen)? I live not too far way..and I've been looking for one of those to experiment with!
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • budwich
          • Jul 2015
          • 3097
          BUT... what do you mean "panel fault"... a lot of these have panel faults ... BUT they can be saved by removing the drivers on the faulty side IF that is the type of panel fault you have... hence the question.
          • advant
            by advant
            02-03-2020, 12:25 AM
          • thetonywarren
            Sharp 4P-B43EJ2U wont turn on
            by thetonywarren
            Sharp TV/Display, wont turn on. Brand new, used for maybe 30 minutes. Possibly heard pop then set went dead. I took a look at the boards, no visual damage to boards. The led power indicator is ON, remote will not turn on. I verified that backlights do come on when powered with separate power supply/LED tester. I also...
            10-01-2025, 09:30 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • moltensolderlabs
            Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
            by moltensolderlabs
            Hi everyone. [Sorry for the long, detailed post in advance].
            I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
            10-09-2020, 12:01 PM
          • JunkmanJimbo
            Sharp lc-55p6000u won't turn on
            by JunkmanJimbo
            Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
            09-28-2024, 12:56 PM
