Philips 42pfl7603d/10 dead
  • finntricky
    • Jan 2014
    • 449
    Re: Philips 42pfl7603d/10 dead
    already check it, and fine, but no voltage though it or to it, same with all other diodes.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      What T-con goes with this tv again? Then i'll install the boards on a frame and i can measure the voltages for you...
      Back of the power supply still ok? No burn marks etc..
        How did you test it? Were you looking for the Voltages?
        I request you to test the resistance, not Voltage and no power to the TV.
        • finntricky
          • Jan 2014
          • 449
          no burn marks that i can see, and thank you for getting your boards out, but i think im on a losing battle, with this one, and may just put it aside untill i can come by a power supply.
          • finntricky
            • Jan 2014
            • 449
            yes i was looking for voltage, tryed to follow voltage from mains and across F2 it goes though some resisters and reduceing the volts down to 7v AC at a SM cap and then cant get any think after, so then tryed traceing from 3.3 stb pin back into the board and again cant seem to find any voltage,
            so any idea as to what resistance i should get, and from what points do i test ?
              So you did not do the resistance test as I requested, and also the Voltage test on the cap as I requested:
              Post 20:
              Check the resistance of D950, ZD951, ZD902 for very low resistance in both directions.
              Check the to see if you have about 325VDC between the two legs of C902.
              • finntricky
                • Jan 2014
                • 449
                #27
                set my meter on 2000, D950 red on black end of diode and black on silver end =255, reversed =over 2000 so set meter to 20k and got 2.10.
                ZD951 = 256, reversed =over 2000 so set meter to 20k and got 3.12.
                ZD 902 = 634, reversed = 1033.
                C902, is this the main cap,? as on my board it is C808 and no voltage
                  Look for C902.
                  Pictures provided by shopjimmy.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    #29
                    Nah your not on a losing battle! Lets start with the suggestions that budm is giving you. I can send you my PS if you pay for the shipping cost. But try to fix yours first!
                    • finntricky
                      • Jan 2014
                      • 449
                      #30
                      Look for C902.
                      that one, sorry did'nt even look at that because of the voltage you said, so thought it must be the main cap you was after, but yes, tested and got the 335v
                      • finntricky
                        • Jan 2014
                        • 449
                        #31
                        thank you, your so kind, but like you say we will see how it goes.
                          OK, since the diodes in the cold side are not showing Low Ohm reading, looking at the 3.3VSB drive circuit, I can see one commonly fail snubber diode ZD908 (P6KE300A), you should unsolder one leg so you can lift one leg off the board and then test it in Ohm mode and in diode mode.
                          Also check the Fusible resistor R901 (1 Ohm) to see if it shows around 1 Ohm.
                          • Diah
                            • Feb 2013
                            • 6613
                            on first post you wote you placed worked PSY and result same.. so i wrote in post No 2 SSP. dont spend time and nerve on it.. no order signal from SSB to this Delta, refer to Delta training
                            • finntricky
                              • Jan 2014
                              • 449
                              #34
                              ZD908 reads 1860 ohm in direction of flow, and no reading in the reverse mode on ohm set meter at 2000, diode mode is also correct,
                              r901 reads 1.4 ohm set meter at 200
                                BTW, so both power supply boards do not have 3.3Vsb when it is powered by itself, right?
                                  next section to check will be the DCV between the two legs of the startup/running cap C912, and also between the two legs of Aux supply cap C906.
                                  • finntricky
                                    • Jan 2014
                                    • 449
                                    #37
                                    ok, this don't look good, C912 = 0.92v, and C906 = 0.33v and slowly drops, but caps are fine, as have already had them out and checked ESR.
                                    BTW, i only have the one power board,
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #38
                                      I took the working powersupply and plugged in the mains. No other boards connected.
                                      I measure only 3.3V on the 2 diodes on the picture.
                                      I do not measure the 12V etc but thats because the mainboard turns on the rest of the board.
                                      Do you got 3.3v?
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        #39
                                        Ps , they are diodes D950 and D951. So the PS only gives the 3.3v standby which is going to the mainboard.
                                        If you don't have the 3.3V on your power supply then something is wrong. If you do have the voltage then the mainboard does not turn on the PS to generate the other voltages.
                                        If i need to measure something let me know!
                                        • Moreno83
                                          • Jun 2014
                                          • 2008
                                          • The Netherlands
                                          #40
                                          I measure 32V DC on C906 and 10V on C912
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • kew1701
                                            Philips taw6205 ambilight speaker STM32 mcu dead
                                            by kew1701
                                            Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                            04-09-2025, 03:59 AM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
