I have an RCA tv with no backlight. Checking the voltage on the LED connector, the voltage jumps to about 110V at power up, then drop right away and drops down to 40V. I did the flashlight test and thee is video. I assume this means there is a short somewhere in the LED strips.
RCA RLDEDV3255-A no backlight
Re: RCA RLDEDV3255-A no backlight
I would say Open circuit in the LED strings.Never stop learning
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by canadaboy25Hi all,
I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...-
- Loading...
