Hello I have a Samsung L32R71B that has no picture when it is turned on. When the TV is connected to SCART i can hear sound, backlight is also working, the remote control is also functioning. Pretty much everything is working there is just no picture at all. When i press the menu button on the remote nothing is showing on the tv. I have checked the power board and so far i haven't found the problem there. The inverter must be working since there is a working backlight. Does anyone knows what should i check? Has anyone encountered such a problem? I think that the problem might be coming from the main board somewhere, but i don't know what to check. If anyone had such a problem please share your thoughts. Need some hints what to do next with it. Thank you
Samsung Le32r71b no picture
Re: Samsung Le32r71b no picture
We need the pictures of the whole backside of the TV so we can see all the boards, it may be the T-CON is not getting the switched DCV from the main board, or blown SMD fuse on the T-CON board.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
This is my T con board i have this regulater dc voltage mmc6100b is the same with ams1117 in outvoltage i have only 0.8v ???? in enter voltage i have 3.3v it is normal this situation ? ic U 14 see in the photoAttached Filesif you find these attachements useful please consider making a small donation to the site
What resistance do you read between the output pin and GND? Need to find out if the IC is bad or the output is being loaded down or oscillating due to bad filter caps.
Does it get very warm?
Do you get 1.25VDC measured between the ADJ pin and the output pin? It should have 1.25V because of the internal 1.25Vref.Never stop learning
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
Hi All,
Need help.
I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard.... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by JohnML1975Hello All
have seen posts on this model in here but my problem sounded different so thought i would create a thread
TV will not turn on
There is no standby light
When I press ON button for remote the red standby light does flash but no picture and no sound
From the back of the TV I can see the red light on the back of the mother board
Holding torch to the screen I cannot see a picture
I removed the back cover
Observing the boards I cannot see any damage
I disconnected the main board from the power supply
the back... - Loading...
