Vidao 32 inch lcd tv powers on but no backlight or picture
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i have this vidao cheap lcd tv model 32A60
    it powers on....green power light comes on
    however there is no backlight and did flashlight test and has no picture
    i tested some of the voltages and i get
    12v pin= 6v
    24v pin= 6v
    5v pin= 5v
    pson pin= 4.4v
    i tested the 5 caps near these pins 1000uf and 470 uf using a esr meter and in circuit they seem to test and look ok
    the only thing i could see otherwise is the large 450v 16uf cap in the center of the board is bulged on top
    could this be the issue?
    here is a photo of the power supply board
    thanks
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vidao 32 inch lcd tv powers on but no backlight or picture
    Previous thread which may be of some help to you:-
    I replaced one switching Transistor 2n4401 (Q8) which is connected to the opto-isolaters and it works great now.
    https://www.badcaps.net/forum/showthread.php?t=40142
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Thought you said the Psu was blowing up in another thread ?
      • shelby5041
        • Feb 2009
        • 1505
        i have 2 threads
        same board 2 diff problems trying to get one to work to repair vidao 32 lcd
        one blows up main fuse instantly...no matter whats plugged into ps
        and the other gets low voltages
        • shelby5041
          • Feb 2009
          • 1505
          previous thread not same issue as mine
          • shelby5041
            • Feb 2009
            • 1505
            i just looked at previous thread its possible cause of mine his is intermittent mine is 100% low volts all the time so maybe i will swap q8 from one board to the other just for the heck of it and see what happens
            • shelby5041
              • Feb 2009
              • 1505
              one question i have though....the large 450v cap is bulged ....is this an issue or not really?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                I don't know if anyone can tell from the photograph but if you can see that it that it has bulged, then it should be changed.
                • shelby5041
                  • Feb 2009
                  • 1505
                  thank you
                  it is definitely bulged
                  the photo i posted is generic photo
                  one questionb....how long do i have to wait until i can desolder the large cap safely to replace...i want to swap from another board
                  without getting zapped...
                  thanks
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Measure the voltage across the two pins and when it is near to 0V it is safe to do so.
                    • shelby5041
                      • Feb 2009
                      • 1505
                      Update I replaced the 450v cap and q8 and no change still get low voltages
                      Same readings as before
                      Any ideas?
                        Are you getting close to 400VDC between the two legs of that main filter cap? If the PFC Voltage booster is not working the 12v/24V SMPS will not function correctly.
                        BTW, the cap is only 16uF? Not 160uF?
                        • shelby5041
                          • Feb 2009
                          • 1505
                          sorry its 68uf not 16uf
                          and i have not checked for 400v while in circuit
                          is that something i can do safely in circuit?
                          the cap i replaced was bulged....i replaced it with another cap from spare duplicate board i had
                            You should at least plug what ever you are working on into GFCI outlet at the very least.
                            Just have to be careful and not touching anything on the board with your hands or body.
                              If the boosted Voltage is present, then you should check the capacitance of that gray rectangular cap off the board, and if that checked out OK, then we need to find out if the SMPS IC for the 12V/24V has VCC to run.
                              • shelby5041
                                • Feb 2009
                                • 1505
                                update
                                ended up spending too much time getting nowhere over 20 hrs so i bought another power supply for only $15 on ebay shipped and just got it and installed it and tv works great now
                                thanks to everyone who tried to help
                                  Thanks for the follow-up on the outcome, $15 is very good price.
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    yes 15.00 including shipping was a great price
                                    i got the tv for $5
                                    my friend had a property that a tv shop rented and he didnt pay rent so he evicted him and said i could come see what he left behind
                                    tons of older lcd tvs and a few led lcd tv but all were just mix and match taken aprt etc..also lots of misc tv boards laying around everywhere but most were damp from the water ..the shop was in a bad area of detroit and was raining inside and most just junk but i was able to find a few that i considered fixable....i got this one fixed and anohter one actuall powered on fine no repair needed
                                    i got them for $5 each
                                    thanks
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      also i cant find any specs for this ultra low end tv
                                      anyone know the specs?
                                      vidao 32a60
                                        http://www.sibrandssupport.com/
                                        http://www.sibrandssupport.com/32A60.html
                                        https://cdn.badcaps-static.com/pdfs/...a2cb736687.pdf
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • KYBOSH
                                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                          by KYBOSH
                                          Saved this beast from the landfill this weekend.
                                          Manfactured July 2013 in Mexico.
                                          I love working on plasma TVs.
                                          Its been a while but I was lucky enough to find 2 this week.
                                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                          Will start troubleshooting tonight.
                                          10-17-2024, 01:17 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • Acnologia
                                          Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
                                          by Acnologia
                                          Hello to all members of badcaps.
                                          Another brainstorming that i have been messing with for months as a side project.
                                          Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
                                          I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
                                          Step 1.
                                          Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
                                          Machine > Doesn't give display it's really dim.
                                          Step 2.
                                          Use the same...
                                          11-05-2025, 04:02 AM
