LG 55LN5310 dead
  • tech2014
    • Aug 2014
    • 807
    LG 55LN5310 dead
    Customer told me something got thrown at the screen and then the tv went off and it is completely dead, no power LED at all. She said the object was a foam ball and that it hit the bottom of the screen, on the frame not LCD.
    I tested the power supply and the PWR-ON is 0V. I checked the voltages on the main board and they are all jumping around. I jumpered 3.5V into power supply board and all voltages come up on power supply, but they are not stable and jump around.
    Would this point to a bad main board?
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: LG 55LN5310 dead
    When you disconnect all boards,then force on the power supply,how are the voltages then?
    First was thinking that a ccfl tube could have broke on impact,but it's a LED lol
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • tech2014
      • Aug 2014
      • 807
      I get voltages but they are not stable, jumping around. I even checked the 24mHZ crystal on the main board and it is measuring 24MHZ but the waveform is jumping around just like the voltages. With everything connected, I get close to 3.5V on the power supply connector but they are not stable.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        DISCONNECT all board from power supply,then force on power supply,are voltages stable then? As in without all other board?
        • tech2014
          • Aug 2014
          • 807
          no. I used my external regulated DC p/s and put 3.5V on PWR-ON pin. Voltages are there but jumping around, unstable.
          • tech2014
            • Aug 2014
            • 807
            UPDATE
            I found another LG power supply with the exact same pinout as the power supply I am testing. I out 3.5V in and all my voltages were good and stable. I then did the same with the one i am working on, and I found that even the PFC voltage is jumping around and not stable. It is obviously a p/s issue. Only problem is there are a tonne of surface mount components on the back of the board.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Any pictures of the power supply available?
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                I had the same issue with a samsung led. Also jumping voltages. Heating up the powersupply works , tv will turn on....
                Try to heat up the optocouplers area and see if tv will turn on....
                I just replaced the PS and tv worked again! I replaced all caps and even the opto's but i never found the real problem...
                Hope you can pin point the exact issue!
                • Diah
                  • Feb 2013
                  • 6573
                  i think the problem at booting voltage, is it chassis LA32B ?
                  make sure Micom voltage on L301 +3.5V_ST. if less or unstable change it.
                  also as i think the CLK Is 10MHz not 24MHz as you wrote.
                  • tech2014
                    • Aug 2014
                    • 807
                    Here are pics of the power supply.
                      LG EAY62810701 (3PAGC10124A-R) Power Supply / LED Board
                      http://www.shopjimmy.com/lg-eay62810...upply-unit.htm
                      So this the board, right?
                      Pictures provided by shopjimmy.
                      • tech2014
                        • Aug 2014
                        • 807
                        yup
                          So the 3.5VSTBY is not stable at this point, right? The transformer T501 that generates the 3.5VSTBY also generates the dc (AUX winding of T501) through the switched (Q501) Voltage to provided VCC for running PFC Controller IC and the other SMPS IC.
                          You already inspect the board real close for any bad solder joints?
                          You can try heating up those small caps in the primary side by the 3.5V stby IC to see if the 3.5V will be steady and the PFC Voltage will be steady, see post 11.
                          • tech2014
                            • Aug 2014
                            • 807
                            yes, checked for bad solder joints, all seems ok.
                            So this is a power supply problem like I suspected?
                              Well, if I understand you correctly, the replacement power supply board is installed and the TV function and you have steady PFC Voltage, steady 5.3V STBY, etc, right?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Before you do any type of repair does the Lcd look smashed ? You can tell by shining a torch on it.
                                • tech2014
                                  • Aug 2014
                                  • 807
                                  The replacement power supply I tested has the exact same pinout as the original power supply. Will it hurt anything if I install this p/s into the tv to see if the power comes on.
                                  The replacement p/s is part number EAX65423801. Here is a link to it on shop jimmy.
                                  https://www.shopjimmy.com/lg-eay6307...-led-board.htm
                                    That is not the same setup as the one we are working on at all.
                                    Good question abut the screen by reece.
                                    If you look at the Voltages chart on the board, the LEDs Voltage is not the same.
                                    • tech2014
                                      • Aug 2014
                                      • 807
                                      yeah I just noticed that budm. I think I may just order a new power supply since there are too many surface mount components on the board and without a schematic, its too difficult to repair.
                                      Also, there was no damage to the screen as far as I can tell.
                                      So does everyone agree with me that it is a p/s problem?
                                        Did you try running the the TV board without the T-CON board connected to the main board? I cannot see how foam ball hitting the frame of the TV can knock out the TV.
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • kevin_allein
                                          Samsung QE 75 Q 7 FGMTZG Power Supply dead
                                          by kevin_allein
                                          Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                                          In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                                          Does anyone have schematics for that board ?
                                          Any good tip, what could be the issue ?
                                          02-27-2025, 12:15 PM
                                        • khalillll
                                          maxipower 400W Dead power supply repair
                                          by khalillll
                                          The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
                                          After checking, I replaced the UTC7606D IC to restore the 5VSB.
                                          I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
                                          Replaced it again with another UTC7606D.
                                          Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
                                          After checking again, I think the issue was with the UTC7520D IC.
                                          Replaced it with a WT7520.
                                          Result: PSU fully working again
                                          09-27-2025, 05:06 AM
