tv lcd Philips 42pfl9632d/10 Power board ko
  • Bibu
    replied
    Re: tv lcd Philips 42pfl9632d/10 Power board ko
    Originally posted by budm
    If you look at the SCH I provided, you will see that 3014, 3017 are 100R resistors which are 100 Ohms resistors, not 10 Ohms resistors.
    So are you for sure that the MOSFET 7005, 7006 are really shorted out because you said it did not blow the main fuse.
    Right now we need to fins out what DCV you have on the cold side of the power supply connectors.
    Budm but the resistors that i post Now in photo aren't 10 ohms? All calculator program tell this.
    In what particular point of the cold side would you like that i test?
    replied
  • Bibu
    replied
    3014 and 3017, are after the 3308,near the two mosfet.
    I just tested it removed from the board, and the multimeter show 96 ohms
    replied
    If the resistor is marked as 10 Ohms and it is tested as 96 Ohms, then it is bad, you can also remove it from the board to test it also since any residue Voltage left on the board will also cause the Ohm to read wrong.
    Which 10 Ohms in what section of the board?
  • Bibu
    replied
    But it's possible that a 10 ohms resistors at the test Give 96 ohms?
    replied
    Originally posted by Bibu
    3305 and 3306 are resistors?
    3304, 3305, 1005, 1003/1303 are part of the protection circuit, they are not the problem, they are not needed for the board to function.
    You can see how they are used in the SCH I attached.
  • vinceroger69
    replied
    yes thats about right for them
    https://www.easycalculation.com/phys...color-code.php
  • Bibu
    replied
    230 ohms
  • vinceroger69
    replied
    yes they are both resistors what do they measure?
  • Bibu
    replied
    Ok this is the photo
  • vinceroger69
    replied
    have you got a picture? i havnt downloaded a service manual myself but a picture will tell us what they are
  • Bibu
    replied
    Kiriakos GR
  • vinceroger69
    replied
    Kiriakos GR
    Cheers budm its been a while since hes been mentioned in any threads etc.
    just saw his site
    http://www.ittsb.eu/
  • ReeceyBurger123
    replied
    Jeez I think its just the translation between Eng and Germ which is causing this but its hard to make it all out
  • ReeceyBurger123
    replied
    https://www.badcaps.net/forum/showpo...9&postcount=25
    Be careful, do not quote his comments!
    I wonder what the 'QUOTE' button is for then.
    Lol im going to read that now didnt see it was updated
    replied
    Originally posted by ReeceyBurger123
    I wasn't around for that era unfortunately
    Kiriakos GR
  • ReeceyBurger123
    replied
    Youve got me thinking now lol i know the greek man you mean but i cant remember his user name, im not sure reece was around then but i do agree with you about the greek resurrected quote.
    replied
    'ReeceyBurger123 i have on hand new nick name for you hahahah ReeceyBurger123PANEL hahahah you are very expensive at repair LOL'
    You would have won big bet from the so called 'PROFESSIONAL TECH'. Who is laughing now?
    How many times now that we were told they are not panel problems?
    Originally posted by Diah
    don't put your ass between other talking, when i write to some one you don't have right to make comment or quote it, and from now on don't quote my name any more. end.
    it seam you are still kids, don't worth any more to comment but at the last one you should know and keep it like ring at your ears .... electronic like ocean and you still swimming at baby beach.
  • vinceroger69
    replied
    Originally posted by martino
    In his delusional mind they probably do,he sees every tv as a Salvadore Dali project. Unless he's just talking out of his a$$ as usual. I call him the greek resurrected.
  • ReeceyBurger123
    replied
    Probably, I seen the other post he commented on about that "bad panel" on that Panasonic 58" and your reply, that was jokes haha Ohh well will let him get one with it and just correct when needed lol
