Re: tv lcd Philips 42pfl9632d/10 Power board ko
Budm but the resistors that i post Now in photo aren't 10 ohms? All calculator program tell this.
In what particular point of the cold side would you like that i test?
If you look at the SCH I provided, you will see that 3014, 3017 are 100R resistors which are 100 Ohms resistors, not 10 Ohms resistors.
So are you for sure that the MOSFET 7005, 7006 are really shorted out because you said it did not blow the main fuse.
Right now we need to fins out what DCV you have on the cold side of the power supply connectors.Leave a comment:
3014 and 3017, are after the 3308,near the two mosfet.
I just tested it removed from the board, and the multimeter show 96 ohmsLeave a comment:
If the resistor is marked as 10 Ohms and it is tested as 96 Ohms, then it is bad, you can also remove it from the board to test it also since any residue Voltage left on the board will also cause the Ohm to read wrong.
Which 10 Ohms in what section of the board?Leave a comment:
But it's possible that a 10 ohms resistors at the test Give 96 ohms?Leave a comment:
yes thats about right for them
https://www.easycalculation.com/phys...color-code.phpLeave a comment:
yes they are both resistors what do they measure?Leave a comment:
have you got a picture? i havnt downloaded a service manual myself but a picture will tell us what they areLeave a comment:
Cheers budm its been a while since hes been mentioned in any threads etc.
just saw his site
http://www.ittsb.eu/Last edited by vinceroger69; 03-17-2016, 05:46 PM.Leave a comment:
Jeez I think its just the translation between Eng and Germ which is causing this but its hard to make it all outLast edited by ReeceyBurger123; 03-17-2016, 05:40 PM.Leave a comment:
https://www.badcaps.net/forum/showpo...9&postcount=25
Be careful, do not quote his comments!
I wonder what the 'QUOTE' button is for then.Leave a comment:
'ReeceyBurger123 i have on hand new nick name for you hahahah ReeceyBurger123PANEL hahahah you are very expensive at repair LOL'
You would have won big bet from the so called 'PROFESSIONAL TECH'. Who is laughing now?
How many times now that we were told they are not panel problems?Last edited by budm; 03-17-2016, 05:33 PM.Leave a comment:
Youve got me thinking now lol i know the greek man you mean but i cant remember his user name, im not sure reece was around then but i do agree with you about the greek resurrected quote.Leave a comment:
Ohh well will let him get one with it and just correct when needed lol
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by spantorHello partners.
Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
