JVC LT-40DJ51J - Vestel 17IPS20 - LEDs very dim
  • tn245
    • Oct 2013
    • 530
    Got this TV. Owner said the screen went dim so he turned the backlight up to counteract which worked for a while but eventually it went almost black.
    The LEDs are lighting up only just, three of them not at all on one strip. Have tested all the LEDs following ReeceyBurger's excellent video instructions and they all light up nicely. Voltage to the LED string from the PSU is only ~105V. I think this should be closer to 150V for 45 LEDs am I right? So I think this is a problem with the PSU. Just wondering if any of you have come across this before and can save me some time chasing down the problem.
    Thanks!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: JVC LT-40DJ51J - Vestel 17IPS20 - LEDs very dim
    Hi mate, thanks for the feedback on the vid Your on the right path, the drive voltage is way too low. Possibly a shorted Led dragging down everything or maybe the drive amplifier is not turning on the mosfet enough. Silly question but what is the backlight setting at ?
    • tn245
      • Oct 2013
      • 530
      Hi ReeceyBurger. You're welcome. The videos are really helpful. As I said I tested all the LEDs and they all light up when tested in groups using the ATX psu method, which leads me to suspect the PSU. I did wonder what the backlight is set at but I'm not getting enough light output to see the screen at all so I haven't managed to check it. He said he'd turned it way up.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hmm yeah deffo something wrong with Psu then, normally if the Led booster mosfet or diode shorts then the Tv wont turn on at all. Sounds like the controll Ic for the mosfet has failed. It seems to be quite common on these Vestel Psu/Led drivers. I will put an ebay link to the Ic.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Think this is the kit you will need:
          http://www.ebay.co.uk/itm/VESTEL-17I...8AAOSwHPlWesfB
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I would say replacing the controller will likely fix the issue but you can replace the fet too if you want.
              I see three of the LEDs are not on, are you sure they are not shorted out? If they are shorted out then the boost circuit will not be on, the 105V is the feeding Voltage to the booster circuit to raise it up higher by the booster. If those 3 LEDs are shorted out it will trip the over current protection circuit.
              BTW, please also up load the pictures of the bottom side of the power supply-LED driver board.
              • tn245
                • Oct 2013
                • 530
                Budm, you're right those three don't light up under the TVs own power, but they do light up when powered up separately.
                ReeceyBurger I will check out that controller thank you.
                  So if you leave the meter probes between the two legs of the booster output filter cap (47uF200V) laying on its side next to the LED connector then turn on the TV, do you see it jumps much higher than 105 VDC and then drops down to 105Vdc later on?
                  • tn245
                    • Oct 2013
                    • 530
                    123V and it stays there.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      i would change the three leds which budm has pointed out maybe there on the verge of failing, in not sure if its worth changing that led strip for a diffrent location and see if the fault moves if it does it has to be that strip i guess.
                        Please try it again but without the LED connector in place.
                        Also can we get the good clear pictures of the bottom side of the board?
                        The Diode (boosted Diode) on the top right of the board next to that small boost inductor L5201 tested OK?
                        https://www.badcaps.net/forum/attach...4&d=1458058395
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Well if he said they light with the meter probably means they are ok.... If one was shorted the meter will beep or show 0 ohms.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Im currently doing the same panel now, I actually have 2 failed O/C Leds causing no Bl though. Will let you know what the drive voltage is when I fix mine.
                              I expect it to be around 150~160 range.
                              • Diah
                                • Feb 2013
                                • 6574
                                you need to test the Diode of the LEDS especially the off on, if the Diodes should read 785-750 any less than this average Bad Diode it lights but it limited the passing currents to the next one.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Led drive voltage on 17ips20 for Ves400:
                                  Backlight on Low: 162v Dc
                                  Backlight on Med: 165v Dc
                                  Backlight on High 169v Dc
                                    I wonder if he is getting the BL-ON to start the booster circuit or not.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Im quite sure he would be, these mainboards if the Blon was at fault im sure lock out and fail to give standby Led. Common fault is the Ic that drives the fet fails absolute crap Tv's Budm.
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        Thanks for all the suggestions guys. I'm going to have to wait until tomorrow to do the tests suggested. Will report back.
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                        • nick4275
                                          Vestel Based JVC no picture, leds on
                                          by nick4275
                                          Hoping someone has troden this path before !
                                          I'm looking at a JVC LT-39c790 - a vestel based unit.
                                          So, the remote turns it on, led's light up but no picture at all.
                                          I have a spare mainboard, so I know its not that. The PSU seems ok too.
                                          On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
                                          So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package...
                                          11-21-2023, 04:43 AM
                                        • psdavid65
                                          Toshiba 40L1333DEV Vestel 17IPS20
                                          by psdavid65
                                          Quick Question Please.
                                          Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
                                          All other components on this vestel board have valid readings except for this U202 IC.
                                          09-21-2023, 12:29 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • lmcancu
                                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                                          by lmcancu
                                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                                          Instead of putting it back together I decided to replace...
                                          04-01-2023, 01:11 PM
