Panasonic Viera TC-L32U22 no picture
  • Diah
    • Feb 2013
    • 6435
    Re: Panasonic Viera TC-L32U22 no picture
    Originally posted by dick_barton
    I'm not sure at this point but the Tcon appears looking at the manual to be an integral part of IC8001 so perhaps this has suffered from poor solder connections and is one for the oven treatment.
    yes its, but this not for oven treatment, as A Board double side. better with hot air gun
    • pr0cess0r
      • Jan 2011
      • 110
      i dont find at test point on the pcb...
      • Diah
        • Feb 2013
        • 6435
        any way, its all give suspect of IC8001 go head to rebel it.
        also check if the sound it had realy 15 Volts, as it share this with LVDS
        • pr0cess0r
          • Jan 2011
          • 110
          rebel?! reflow?
          • Diah
            • Feb 2013
            • 6435
            yes lol...
            • pr0cess0r
              • Jan 2011
              • 110
              #26
              i will try it!
              • pr0cess0r
                • Jan 2011
                • 110
                #27
                afther more observation i think that the pcb got damaged by liqid. The black stamp whit the sufix code look whashed and some via have corosion ont theme.
                • Redrum
                  • May 2015
                  • 19
                  sorry to bump this 2 1/2 year old post, but I have the exact same TV with the exact same problem - Power LED on solid, no blinking, no picture, but there is a backlight (you can see the backlight level change on input change), no picture, no sound**
                  ** I have not tested sound on all inputs, just for the hiss on the RF input.
                  Was this issue ever resolved for the unit in this thread? I thought I would ask before I button it back up and take it to electronic recycle.
                  Jim
                    • 12276
                    • U.S.
                    #29
                    Check if you have 12 volts on each side of the tcon fuse, may have to look closely, the fuse should be labeled starting with Fxxx.
                    • Redrum
                      • May 2015
                      • 19
                      thanks for the tip. But, I am not finding a tcon fuse. The only fuse I see is on the line. I have attached a snapshot of the block diagram for the service manual which show tcon12v being sourced by DTV12.
                      See attachment, am I looking in the right spot? P board or A Board?
                      Jim
                        • 12276
                        • U.S.
                        #31
                        Not exactly sure, I'm not too familiar with the integrated tcons.
                          You should show us the pictures of the T-CON board which means you have to remove the metal frames on the LCD panel to get to that integrated T-CON.
                          • Redrum
                            • May 2015
                            • 19
                            thank you, please see the pictures. Is this what I am looking for? The second picture just shows the portion of the board where the ribbon from the A board connects.
                            I'll look the board over next, but if you have any guidance, that would be great
                            Jim
                              Pictures are too blur to be able to identify anything on the board.
                              https://www.badcaps.net/forum/attach...5&d=1544124298
                              The fuse looks to be to the right of that LVDS connector.
                              • Redrum
                                • May 2015
                                • 19
                                ok, I originally took the pictures to say "is this where you mean?". I'll be happy to take all that are needed. Then, on trying to load them (as a jpeg) to the website it said invalid extention for png"????
                                Anyhow, here is another shot of the area. I see no fuses on the entire board, just smt components.
                                anyhow, as a reminder, solid LED on (not flashing), no picture, no sound, but I see backlight
                                Jim
                                  Need to zoom in to the area as marked in the picture.
                                  • Redrum
                                    • May 2015
                                    • 19
                                    thanks, this is the best I can do. I don't have a macro lens. Took this full res, then cropped in photoshop.
                                    what am I looking for?
                                    In everything I have found, this TV has a P (ps) board, an A board, and two other little boards for the input/controls and the IR. The panel seems to be treated as an assembly. If you look at the manual in one of the first posts, the block diagram represents this. In searching for parts, only the A, P, and two little boards are represented.
                                    So, I am thinking if the issue is indicative of the display control, and we can't find a smoking gun, perhaps it's time to recycle....
                                    Jim
                                      https://www.badcaps.net/forum/attach...3&d=1544132121
                                      Check to see if you have 12V at pin 1, 2, or 5 of that LVDS connector with ref to chassis GND when TV is turned on.
                                      BTW, what is the LCD panel number as printed on the sticker?
                                      • Redrum
                                        • May 2015
                                        • 19
                                        good morning,
                                        I really don't have any way of probing that fine of a pitch on the connector. There must be a test point somewhere.
                                        I have attached a picture of the label on the panel.
                                        Also, I have attached a screenshot of the block diagram to the panel (from the service manual), and two screen shots of the schematic for that 80 pin connector. perhaps if you could point me to what I am looking for, I can trace back to find a tp on the a board.
                                        I ask because I see alot of reference to 13.7v, but none specifically to 12v other than the one area in the previous post. If I am going to test and determine go/no go, I want to make sure I am testing what you are suggesting I test
                                        Thanks;
                                        Jim
                                          LCD panel connector VCOM Pin 2 and 3 are tied together so you can probe on the copper trace, AVDD13.7V pin 5 ~9 are also tied together and connected to r86 so your meter probe should be able to test those pins.
                                          It looks to be that this panel has many Voltage sources to feed that panel.
                                          You can always trace out the connection from the pin that goes to other places so that you can probe the Voltages.
                                          • FZG
                                            Panasonic AG-1000B VHS player with bad picture quality
                                            by FZG
                                            Hello!
                                            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                            I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                            Also, what mechanism is this?
                                            Any feedback is appreciated!...
                                            05-06-2024, 07:16 AM
                                          • Bazfletch3
                                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                            by Bazfletch3
                                            Hi all
                                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                            From there I envisaged that the backlighting wasn't working, however...
                                            01-08-2024, 10:18 PM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • mar1in
                                            Panasonic TH-55AS670A no picture no sound
                                            by mar1in
                                            I've got this Panasonic TV here with the following symptoms:
                                            * Standby Light is solid RED
                                            * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
                                            * After a couple of seconds, LED is solid GREEN and without picture or sound.
                                            I've tried a couple of things before tearing it apart:
                                            * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
                                            * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
                                            09-10-2023, 11:10 PM
