Panasonic Viera TC-L32U22 no picture
  • Redrum
    • May 2015
    • 19
    Re: Panasonic Viera TC-L32U22 no picture
    got it: power off (unplugged), standby (plugged in wait a few seconds), power on (press power, wait for the "click" and the backlight glow).
    Understand state changes.
    I'll take a few more thorough measurements later today...
    Jim
    • Redrum
      • May 2015
      • 19
      OK, I have managed to convince myself of one thing. I don't understand the power distribution scheme or mechanism, so I don't understand what's going on, what controls what.
      I had assumed that the PS board produces the 12v which IC4800 converts to AVDD13.7V and DVDD2.5V. I had further assumed that PANEL_VCC_ON and VDD25_EN are the respective enable lines to allow IC4800 to generate the voltages.
      I am assuming (for now, by inferring from the block diagram) that PANEL_VCC_ON controls AVDD31.7V and VDD25_EN controls DVDD2.5V.
      So, the measurements:
      Nothing at plugged in and power off.
      The power on sequence - press power button - a few seconds - click - a second, back light comes on.
      None of the voltages are present until the click. At/after the click:
      Tcon12 (pins 12, 13, 23, 38, 37) = 12.0V <expected>
      AVDD13.7 (pin14) = 0.5V <expect higher>
      DVDD2.5 (pins 32, 33) <expected, note that this occurs after click, at backight>
      logic lines:
      PANEL_VCC_ON = 3.0v <logic true for the 13.7 panel voltage?>
      VDD25_EN = 3.0v <logic true for backlight maybe?>
      so, my conclusion, again, not knowing the mechanism or, if this is even why the display does not turn on is this:
      With 12v to the IC, and the logic true turning on the 2.5V, why isn't the other logic true turning on the 13.7V (measured at IC pins)
      I could not find the SOS on the schematic although it is shown on the block diagram.
      Finally, in the interest of cause and effect. This TV worked fine, then travelled 4 hours on the NYS Thruway, then plugged in power on, did I see the screen initially? Don't remember. That is why I initially thought to open up and reseat connectors, which I did.
      This has been fun, but I am close to buttoning up the body and take it to the morgue.
      Jim
      • nomoresonys
        • 12276
        • U.S.
        #63
        logic lines:
        Jim
        Guess its possible that the move knocked loose a connection, maybe try plug and unplug all connections a couple times.
        • Redrum
          • May 2015
          • 19
          Yea, that's what I originally thought but I did reseat all connections. After that all of this testing has taken me down this rabbit hole where I know what I am seeing isn't right, but not sure if I am seeing the smoke or the fire.
          Jim
          • nomoresonys
            • 12276
            • U.S.
            #65
            Very strange that it worked fine til the move, wonder if it might have gotten a slight crack in the screen.
            • Redrum
              • May 2015
              • 19
              but at this point I am not seeing any voltages leaving the a board and going to the screen. I usually think cause and effect (broken due to transport), but perhaps it was coincidence.
              • FZG
                Panasonic AG-1000B VHS player with bad picture quality
                by FZG
                Hello!
                I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                I want to know, is this something that could be solved by recapping or is the video head likely gone?
                Also, what mechanism is this?
                Any feedback is appreciated!...
                05-06-2024, 07:16 AM
              • Bazfletch3
                Panasonic TH-65FX800A backlight LED's working but picture is very dark
                by Bazfletch3
                Hi all
                While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                From there I envisaged that the backlighting wasn't working, however...
                01-08-2024, 10:18 PM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • mar1in
                Panasonic TH-55AS670A no picture no sound
                by mar1in
                I've got this Panasonic TV here with the following symptoms:
                * Standby Light is solid RED
                * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
                * After a couple of seconds, LED is solid GREEN and without picture or sound.
                I've tried a couple of things before tearing it apart:
                * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
                * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
                09-10-2023, 11:10 PM
