Emerson LC320EM2 blown fuse but thats not all
  • Hexxus
    • Mar 2016
    • 15
    The post here:
    1. https://www.badcaps.net/forum/showthread.php?t=27899
    2. https://www.badcaps.net/forum/showth...light=LC320EM2
    have similar boards and if not exact problems pretty close to mine
    Here is a repair kit I found that I thought about getting: http://www.shopjimmy.com/emerson-a17...repair-kit.htm
    I am trying to find out what is wrong with this power supply. It blew a fuse, put another one in and it blew as well so something deeper is the problem.
    I only have a multimeter atm to work with, I will be getting a solder gun shortly.
    Board info:
    Ive test for a short in this picture:
    all three legs short to each other. componet data sheet
    2-3 = 0.3
    1-2 = 0.4
    1-3 = 0.4
    In this picture, testing the green resister ohms i got .5:
  • Hexxus
    • Mar 2016
    • 15
    Re: Emerson LC320EM2 blown fuse but thats not all
    Bump
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      remove that fet off the board,measure board at the 3 pins if short is now gone.
      Good picture from bottom of board around that area? also one from top?
      They list the components in that repair kit.I would for sure test all those.
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • Hexxus
        • Mar 2016
        • 15
        Thanks for the reply. Solder station is on the way :P Will get back to you ASAP.
        • Hexxus
          • Mar 2016
          • 15
          Solder pads on board
          pins 1-2 = 1 on meter no beep)
          pins 1-3 = 320ish on meter no beep
          pins 2-3 = 1500ish on meter no beep
          testing the pads image, numbers but no beep. I am not sure what that means.
          Fet pins
          all pins short to each other (beep)
          Images
          Bottom 1
          Bottom 2
          Top
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            I would retest that with the meter on the 2000 ohm scale.If no reading,move it to the 20k ohm scale.
            Right now meter is trying to read voltage drop on a diode.
            Pictures without using flash,we need to be able to see the traces and components
            • Hexxus
              • Mar 2016
              • 15
              Retest the fet diode pins or the solder pads on the board? The last results here:
              Are the pads on the board using the continuity/short setting as shown here: http://i.imgur.com/7it09aG.jpg
              The FET diode pins on 2000 ohm and 20k ohm
              1-2 = 0
              2-3 = 0
              1-3 = 0
              on 200 ohm
              1-2 = 0.9
              2-3 = 0.4
              1-3 = 0.7
              fet solder pads on board
              1-2 = 1180 @ 2000 ohm
              2-3 = 1700 @ 2000 ohm
              1-3 = 325 @ 2000 ohm
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                Fet is toast for sure. The 325 ohm between pin 1-3 on the board concerns me,but I cant see in those pictures what connected there. Can we get better pictures from top and bottom,that clearly show the traces around that dead fret etc?
                • Hexxus
                  • Mar 2016
                  • 15
                  Ill get a better camera and snap some pics in the morning.
                  • Hexxus
                    • Mar 2016
                    • 15
                    I have been a little busy so I will get the pics asap. I received the repair parts I ordered, just waiting on the soldering station now.
                    I would like to test these parts before I go installing them. I am sure they are good as they should be new but you never know. I suppose I just look up the specs and test for it? I have never done that before.
                    • Hexxus
                      • Mar 2016
                      • 15
                      While testing these I was getting strange and wildly changing readings. After messing with the multi-meter a couple times I would get a steady reading.
                      Pictures aren't of the actual part I received but look like them.
                      I am calling these parts by what they are listed on the website I ordered them from.
                      # - Part type - Model? - test results - setting - locations
                      2x Resistors 5W2.2RJ = 2.4 @ 200 ohms (Location R602, R11)
                      1x Resistors Colors (L to R): Brown Grey Silver Gold [ 0.18 ohms 5% tolerance?] = 0.4 @ 200 ohs (Location R608)
                      3x Diodes Unknown # = 660/870/890 Diode (Location D670, D610, D604)
                      1x Diode Unknown # = 340 Diode (Location D640)
                      1x Transistors D667 AC 9H2 = Don't know how to test or got strange results (Location Q601)
                      1x Transistors FQPF13N50C = Don't know how to test or got strange results (Location Q600)
                      1x Fuse F 4A 250V = Visual inspection not burnt/broken (Location F601)
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8344
                        I've repaired this before and others too. Look at this thread and check the components. Some components have to be unsoldered (because of the circuit they are in) in order to measure correctly.
                        https://www.badcaps.net/forum/showth...hlight=emerson
                        • Hexxus
                          • Mar 2016
                          • 15
                          Some components have to be unsoldered (because of the circuit they are in) in order to measure correctly.[/url]
                          The components I list tested above are brand new.
                          • Hexxus
                            • Mar 2016
                            • 15
                            Maybe these are good?
                            • jetadm123
                              • 2169
                              In the previous post, last picture. Is that blue capacitor next to the yellow transformer cracked in half?
                              • Hexxus
                                • Mar 2016
                                • 15
                                That is actually a beard hair of mine :P
                                • woodman45
                                  • Aug 2015
                                  • 87
                                  • U.S.A
                                  Look at post #11 in this thread for service manual
                                  https://www.badcaps.net/forum/showthread.php?t=49250
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8344
                                    I had forgotten about this one...
                                    • Hexxus
                                      • Mar 2016
                                      • 15
                                      Thanks for posting this. I however have no idea what I am looking at with all that technical blueprint.
                                      • woodman45
                                        • Aug 2015
                                        • 87
                                        • U.S.A
                                        Most service manuals have a troubleshooting chart of symptoms and of what to test.plus it gives specs to different parts.i posted it to use for reference.
                                        If you google how to test diodes and different components with a multi-meter there are a lot of vids out there that will help.
                                        I've repaired a few of these boards and found that you're better off to replace every component that comes in the repair kit.
                                        Good luck👍
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • whc14765
                                          Gigabyte 980TI Windforce - Blown PCIE Fuse
                                          by whc14765
                                          Hey,
                                          I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
                                          The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
                                          I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
                                          1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
                                          04-08-2022, 06:22 PM
