Emerson LC320EM2 blown fuse but thats not all
  • Hexxus
    • Mar 2016
    • 15
    Re: Emerson LC320EM2 blown fuse but thats not all
    Originally posted by woodman45
    If you google how to test diodes and different components with a multi-meter there are a lot of vids out there that will help.
    Good luck👍
    If you look here: Post #11
    I got the kit in and tested all but two parts cause I was unsure even when watching the videos. Id like to point out that you look at the diodes I tested as one of the three I tested gave the result of 660 when the other two gave me a 880. I heard in a video 500 would be a bad diode. I also tested a SMD diode and received a low number there as well so I am not sure if I get bad parts in the replacement pack or not.
    • woodman45
      • Aug 2015
      • 87
      • U.S.A
      Maybe someone can chime in that knows for sure.
      I'm at work and don't have anything to go by to answer that question.
      • ZnsaneRyder
        • Oct 2015
        • 88
        • Merica
        This is a TV with a well known power supply issue. It almost always blows the same parts every time.
        Those TV have a 27V Zener, 36V Zener that blow constantly, Main MOSFET (replace with a higher rated part), and a small NPN transistor. You replace all of those, and also a 0.18 ohm and replace the dual 2.2ohm resistors with a standard green power supply thermistor, and it will probably work. There are even youtube videos on this very TV set!
        • Hexxus
          • Mar 2016
          • 15
          I received three Zener diodes. I tested them to the best of my knowledge, two came out 880+ and the other 600 which from the YT I watched makes me think that is bad.
          I received one but I I don't know if higher rated though the website I got the parts from says that the parts exceed OEM standard.
          a 0.18 ohm
          Look here at post 11 I tested the parts I received and I am not sure I got a good resister.
          This here do you mean the ceramic resistors?
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8326
            Diodes measure different. The voltage drop you measure in diode mode isn't always the same. Zeners have a different voltage drop than a Schottky etc. So take one leg off the board and measure the diode both ways. If it is shorted it is bad. If you get readings both ways, its bad also. Compare it to the replacement. But one leg off the diode has to be off the board, so you measure out of circuit. D640 was always a fail. Anyhow when you read the other threads there have been many parts already identified, some are not in your kit. So check them on your board. Resistors usually go higher in value or open. If any of the legs of the mosfet are shorted, it is bad. I think you are concerned about the resistors not giving quite the correct reading. Well... Unless you have a calibrated quality DMM there isn't going to be a way to verify. There are tolerances on the parts and there are also tolerances in your meter. To me the readings don't look too bad. So exchange the bad parts, check the others that are identified in previous threads and go from there.
            • Babbar
              by Babbar
              04-12-2024, 01:12 AM
            • drscoot
              HP X360 convertible battery blown fuse error, not charging
              by drscoot
              HP Modelnumber: 14-dh0061nb​
              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
              All these 3 batteries are charging...
              12-15-2023, 05:54 AM
            • beetle1303
              Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
              by beetle1303
              I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
              On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
              01-13-2025, 08:49 PM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
            • whc14765
              Gigabyte 980TI Windforce - Blown PCIE Fuse
              by whc14765
              Hey,
              I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
              The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
              I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
              1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
              04-08-2022, 06:22 PM
