Smd diode D640
  • woodman45
    • Aug 2015
    • 87
    • U.S.A
    Smd diode D640
    I have repaired an Emerson LC320em2 before with a repair kit for power supply and I have another one that I'm working on.
    I'm hoping someone can help me with the smd diode on D640
    I tested diode in circuit on continuity mode of dmm & it beeps continuously.
    Does this mean it's shorted? I have the old smd diode that I replaced on the other Emerson I repaired & it has the same out come with same test on dmm.
    If any one could give some direction on how to properly test this & maybe some other components of this board I would greatly appreciate because I would love more about how to properly test & diagnose other than throwing parts at it.
  • woodman45
    • Aug 2015
    • 87
    • U.S.A
    Re: Smd diode D640
    Here's some pics of the board I couldn't post multiple pics for some reason.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8326
      Re: Smd diode D640
      D640 that's where the trouble starts... there is more wrong with it yet! So read this: https://www.badcaps.net/forum/showth...hlight=emerson
      btw your diode is shorted. But sometimes things measure a short in circuit. So always double check the parts out of circuit too!
      BTW... replace D640 with a beefier diode in amp and power rating. I used a FR207 as that is what I had on hand at that time but a 3A diode would be better.
      • woodman45
        • Aug 2015
        • 87
        • U.S.A
        Re: Smd diode D640
        Thanks CapLeaker,
        I've read as many threads on this board.
        Should I start with testing R608 resistor?
        I know that I'll end up getting a repair kit any ways but I would like to learn how to test the most common failed components.again all help & suggestions are greatly appreciated.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8326
          Re: Smd diode D640
          Sure you can start with R608. Resistors can change values (higher than they should be or open circuit), diodes fail short, same as mosfets. Some parts may measure a short in circuit, so you have to lift a leg or take it totally out and measure it again. It's easy to spot an open resistor, but it is much trickier to find one that changed in value, as you would have to compare the measured resistance with the colour coding to the body of the resistor. Good luck!
          • woodman45
            • Aug 2015
            • 87
            • U.S.A
            Re: Smd diode D640
            Thanks again for your advice.in the pic would you recommend this diode?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8326
              Re: Smd diode D640
              I can't remember anymore exactly what voltage rating the original diode d640 was. However that's diode in your last post isn't strong enough in your last post. I thought something like a s320 or mbrs3200, 3A 200V Shottky. Iam trying to remember, but I think the original d640 was a 2A 100V?
              • woodman45
                • Aug 2015
                • 87
                • U.S.A
                Re: Smd diode D640
                Update: I got power supply kit,as I removed parts from the board I discovered that the diodes on d604,d607 were shorted as well as the d640.also the 2 cement resistors were shot and I replaced as well.
                The tv power right up after I replaced all new parts.Thanks for the advice & help CapLeaker.
                • woodman45
                  • Aug 2015
                  • 87
                  • U.S.A
                  Re: Smd diode D640
                  Also here's a pic of the kit I used
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8326
                    Re: Smd diode D640
                    Thanks for the follow up!
                    • woodman45
                      • Aug 2015
                      • 87
                      • U.S.A
                      Re: Smd diode D640
                      Here's a service manual in case there's no one posted in other threads.
                      • woodman45
                        • Aug 2015
                        • 87
                        • U.S.A
                        Re: Smd diode D640
                        Also here's a pic of the cement resistors that I replaced & the way to test them is simply by continuity.if they have continuous continuity there good if not there dead & should be replaced
                        • chronic519
                          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                          by chronic519
                          Hello.
                          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                          Found issue with a RAM block
                          Replaced, green lines gone.
                          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                          Used a good card to test and same results low errors 32+.
                          I am just search for some form of command to do a full test on the GPU.
                          I just ran the mats command with my good GPU and passed after roughly 40 min.
                          The repaired one, ran...
                          05-20-2025, 07:56 PM
                        • dj8452000
                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                          by dj8452000
                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                          02-18-2025, 08:28 AM
                        • MalodicOne
                          macbook pro 820-02100 5v 0 amp
                          by MalodicOne
                          Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
                          Tested all CD3217 and RAA489900:
                          UF400
                          PP3v3_UPC0_LDO- 3.48v, .473 Diode
                          PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
                          USBC0_CC1- 0v, .455 Diode
                          USBC0_CC2- 1.66v, .454 Diode...
                          07-25-2025, 10:49 AM
                        • tvguy12012012120
                          by tvguy12012012120
                          02-07-2025, 05:13 PM
                        • asr
                          Finding replacement diode iPad Pro 3rd gen A1701
                          by asr
                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                          07-09-2024, 06:24 PM
