Emerson LF501EM5F shuts down right after turning on.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    #81
    Re: Emerson LF501EM5F shuts down right after turning on.
    I know you've said that before. I trust you.
    I just don't understand it. Lol.
    I trust Einstein was right about his theories but I don't get them. Lol
    By the way, thanks for your help.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      #82
      Just out of curiosity, has anyone ever come a cross just one bad led?
      Would it be possible to bypass one? Would you notice it on the display?
        You can use 5 1N4007 Diodes to simulate the Vf of the White LED.
        https://www.badcaps.net/forum/showth...335#post612335
        If you are interested in more tear down pictures of various electronics you can see my collections here:
        http://s807.photobucket.com/user/bud...?sort=3&page=1
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          #84
          Cracked the panel. Project done.
          • jackfishbay
            • Apr 2014
            • 12
            • canada
            #85
            I just cracked one of these open....same problem...took a while but once I got the white plastic cover that's over the leds I found one string unplugged....put it back together and it works...think I messed it up though. ..one line of pixels is blue ...
            • JonnyS
              PS4 pro PSU ADP-300CR shuts down when turning on 12V
              by JonnyS
              I would like to ask for your help to troubleshoot a faulty PS4 pro power supply
              I have a st_by voltage ane when i try to power on 12v line PSU shuts off
              i measure lot of components but i don't fins faulty piece ,
              when i try to power on 12v line voltage increasing to ~420v so it looks like PFC was working,
              Now i have no idea what i can do more to fix it and i will be very helpfully to help me in this case.
              10-10-2022, 10:34 AM
            • DXseekerMO
              Emerson LF501EM5F, turns on, logo appears, shuts off, the perfect storm?
              by DXseekerMO
              Earlier this week I got an Emerson LF501EM5F that turns on, the logo comes up, a menu and the channel box come on and it immediately shuts down a split second later.
              This was bought new and went in a Laundromat. From there it was on from 7AM to 10PM every day.
              So why is this the perfect storm? A month ago I got an Emerson LF501EM4 and an EM4A, both will not turn on. The EM4A was struck by lightning and has a serial of DS1 The EM5F has a serial of DS5. The EM4 has a DS4 serial and the chirping transformer problem with a replaced power supply.
              The info...
              04-07-2018, 10:54 AM
            • JDC
              (SOLVED) - Emerson lf501em5f - Turns on, shows logo, then shuts off.
              by JDC
              Issue: Emerson lf501em5f turns on, shows logo, then briefly shows what input it is on, then goes black.
              Solution: Bad LEDs. In my case, there were 2. This repair may not be worth it unless you're doing it for yourself. I'm personally not a fan of Emerson TVs nowadays.
              09-17-2018, 09:58 AM
            • Norrecito
              PS4 pro PSU (ADP-300FR) shuts down when turning on 12V
              by Norrecito
              Hello all,
              I would like to ask for your help to troubleshoot a faulty PS4 pro power supply (ADP-300FR).
              A couple of weeks ago, I've picked up a PS4 Pro (CUH-7216B) from one of the local flee markets. According to the seller, it has a "no power" issue and the PSU is most likely faulty. Based on the cracks on the housing, it was probably dropped.
              Tried it at home and sure enough, it had a "no power" issue. (Pressing either the power or eject buttons had no effect).
              I took out the PSU and opened it. Immediately noticed...
              08-20-2022, 10:26 AM
            • huzo
              HP Omen shuts down when loading OS
              by huzo
              The model is 15ec-1061nm
              Board number is DAG3EDMB8D0​
              SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
              10-29-2024, 12:05 AM
