Vizio E420i-A0
  • eagle00799
    • May 2012
    • 322
    Vizio E420i-A0
    I have this Vizio with sound but no backlights, When I check voltages going to led's I get 130V when turned on but it drops and settles at 65v on the LED1+ and LED2+ terminals. The LED1- terminal will hit 83v and drop to 21.5v and the LED2- will start about 150MV and climb to 199MV and start over, This is with the led's plugged in.
    With the led's unplugged the LED1+ and LED2+ will react the same but the - terminals settle at about .273volts.
    Is it safe to assume I have an LED issues here?
  • CapLeaker
    Leaking Member
    • 8327
    Re: Vizio E420i-A0
    • eagle00799
      • May 2012
      • 322
      Re: Vizio E420i-A0
      So now after testing and determinating which one and how many are bad can the individual led's be purchased somewhere or do they have to be purchased in strips? Are there any good known suppliers?
        Re: Vizio E420i-A0
        next step will be taking the panel to see what kind of LED strips are being used on the board. I forget that you can buy the LG Innotek LED for the replacement, I forget the P/N.
        • eagle00799
          • May 2012
          • 322
          Re: Vizio E420i-A0
          I have 3 bad led's out of 50 on 3 different strips. I was under the impression that if 1 led went out the backlights would not come on. Must not be true?
          Also if I buy 1 strip I should be able to remove 3 led's and replace them instead of buying 3 strips correct? Or how can I figure out the part number so I can order just led's from LG or another source?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Re: Vizio E420i-A0
            There are videos referred to on this site showing how to remove LED's and fit them in place of burnt out or shorted Leds. There's also discussions on stacking them.
            https://www.youtube.com/watch?v=0uBhca7zyXI&app=desktop
              Re: Vizio E420i-A0
              If all the LEDs are connected as one large string using ONE LED driver then if one goes open circuit then the whole string will be dead, in this case you will NOT see the backlights flash on for seconds.
              Then you can have more than one LED driver circuit (you can have up to 12 drivers or more), so in this case you may see the backlights flash flash on for seconds due to the not all the strings are bad.
              All of this is based on good LEDs drivers are OK.
              • eagle00799
                • May 2012
                • 322
                Re: Vizio E420i-A0
                Ok I see how to replace but would sure like to replace with new not used led's.
                • Pipolups
                  Corsair K70 LUX RGB dying LEDs
                  by Pipolups
                  Hi there !
                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                  10-08-2024, 11:58 AM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • imaddicted2u
                  Help with Toshiba (Best Buy) 55L621U
                  by imaddicted2u
                  My friend dropped off his Toshiba (Best Buy) 55L621U for me to try to fix.
                  Here is a list of the measurements I took.
                  When first plugged in...
                  Toshiba splash screen is displayed then goes away after 6 seconds.
                  Power LED blinks 9 times, then goes off after about 45 seconds.
                  My friend said the right 1/3rd of the screen was green. I can't keep it powered on long enough to see for myself but the right 1/3rd of the splash screen is dark. Could the panel be bad?
                  LEDS on 6 seconds, Voltages on 6 seconds.
                  Nothing on flashlight test.
                  No response from...
                  03-26-2022, 11:26 AM
