problem with 42PFL3604D/12
  • olymbou
    • Mar 2014
    • 30
    • lar
    hi frends i have a philips 42PFL3604D/12 i changed the t-con and still the same problem . can anyone help
    Re: problem with 42PFL3604D/12
    Can we see the whole back side of the TV so we can see all the boards?
    • olymbou
      • Mar 2014
      • 30
      • lar
      is this o.k
        OK, I was looking to see if this this TV has FRC (Frame Rate Converter) board or not which may o may not have caused what you are seeing on the screen, it does not have FRC.
        Did you try heating and cooling the main board yet.
        • Diah
          • Feb 2013
          • 6438
          Originally posted by olymbou
          is this o.k
          Philips lack with bad PSU Voltage, replace all caps in 12 volts and 20 volts if the sound need 20.v
          also i i had this fault i found customer play with service menu, go there and find dealer and try verging on
          • olymbou
            • Mar 2014
            • 30
            • lar
            Did'nt do nothing by heating and cooling the main board .i will try caps 12 and 20 volt . ant other solution.
            • janos6662000
              Philips 47PFS7509/12 LCD TV problem
              by janos6662000
              Hi
              I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
              When i applied cable signal to check image, i had normal picture, but TV was restarting.
              I downloaded original firmware and applied the update, but the problem remained.
              From a colleague i received a "factory package software" which is a lot bigger.
              I made another firmware update, but still did not solve the problem.
              Somewhere on the way the error got worse, because at the moment the...
              08-12-2025, 12:54 PM
            • courtcircuit
              Philips HTS8000 home cinema noise problem
              by courtcircuit
              Hello
              I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
              Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
              Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
              I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
              Removed each of tyhe boards
              02-08-2025, 08:22 AM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • THXFX
              samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
              by THXFX
              Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
              I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
              When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
              What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
              I check capacitors and diodes and didn't find any short IN MAINBOARD.
              Measured all power supply...
              03-20-2024, 03:21 AM
