Sharp lc-46d92 screen green
  • Ovalking
    • Jul 2013
    • 57
    • Usa
    Sharp lc-46d92 screen green Work fine just has green shadow
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sharp lc-46d92 screen green
    What do you want us to say to that ??? You want help fixing it or just telling us your Tv has a green screen ? If you want help fixing it give us the following:
    Image of fault.
    Tcon used in Tv.
    • CapLeaker
      Leaking Member
      • 8325
      easy... a spray can of flat black fixes that green on the screen no problem!
      • kokos
        LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
        by kokos
        Hi ! to all fellows out there!
        I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
        I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
        The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
        I tried connected the lan and I can seee TV via local lan (as a device I...
        02-26-2024, 10:48 AM
      • String2016
        samsung np300e green screen
        by String2016
        I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
        07-26-2025, 04:00 AM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • Mad_Science
        Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
        by Mad_Science
        I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
        03-01-2024, 05:05 PM
