Sylvania lcd tv model ld370ss8 works fine for 30 min, then shuts off
  • Na-stang
    • Feb 2016
    • 6
    So, the tv turns on and operates just fine. Runs for about 30 minutes, then shuts itself off. I can then immediately turn it back on. However the length of time shortens, to maybe about 15 min? And then I can again turn it right back on.
    I have read thru all the threads on this forum concerning similar issues with like sets, and have checked all of other fixes, including:
    The wires that connect the bulbs to the transformers arcing. I made sure they were separated and not touching, and placed cardboard in between the wires to make sure there was no arcing. Still shut off.
    Examined the mut board extensively. No cracked solders.
    I checked the readings of the secondary windings on the transformers that power the bulbs. There are 8 total. Unfortunately I only have an analog meter. One of the transformers does appear to be slightly lower than the other 7, but it is so hard to be sure with the analog meter. I checked it back and forth several times against the others, and it really looks like it is a hair off of the others.
    Any suggestions? Comments?
    Any help would be greatly appreciated.
  • sordids999
    • May 2013
    • 2156
    Re: Sylvania lcd tv model ld370ss8 works fine for 30 min, then shuts off
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • CapLeaker
      Leaking Member
      • 8222
      Can you be more specific what exactly happens? Does the backlight go out and the rest keeps running or does the whole TV turn off by itself?
      • Na-stang
        • Feb 2016
        • 6
        The whole set shuts off. Green light goes out, red stand-by light comes on.
        • Na-stang
          • Feb 2016
          • 6
          Admittedly I am a novice at best at this. And at the low end. So, laymen terms would be great. I was required to take an intro class to electrical engineering, so I know at least what the components are supposed to do and how to make readings, but beyond that, these boards look like its from an alien spaceship to me.
          • CapLeaker
            Leaking Member
            • 8222
            If the TV shuts totally off, than the trouble should be on the main board.
            To test this, you could force the PSU and the backlights on with the main board disconnected. Sounds like some firmware or eeprom issue.
            • Na-stang
              • Feb 2016
              • 6
              Would this be the main board, correct? If so, how do I force the psu (and what is that?) and the back lights on with the main board disconnected?
              • CapLeaker
                Leaking Member
                • 8222
                the main board is that board that has all the hdmi video input jacks, the antenna jack etc. That brown board on your last pic is the PSU (power supply). This Sylvania looks similar like a Emerson. Those guys (Funai) like to split their PSU's and actually have another one that does the backlight's (first pic). The problem is that I can't see any pin outs to see what is what. Some set's have them printed on the back side of the board, others have none. If that's the case we are SOL unless there is a service manual / schematic diagram to figure things out.
                • Na-stang
                  • Feb 2016
                  • 6
                  Let me see what I can do for you. If I have to, I'll draw a schematic of it all and clearly mark what is hooked to what and where everything else leads off too.
                  • Shane711
                    • 493
                    The case is not always the main board for this TV. I just got done fixing one doing the same thing. The TV would turn on and right back off. The problem was the lamp wires were shorting out. I wrapped the wires with electric tape and the TV was fixed.
                    I am having another issue with it now, no power to the DVD player so I have to figure that one out.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      If the TV is turning off in progressively shorter time, can I suggest you use a can of freezer spray and see if you can cool the components on the power supply to see if it changes the time to return to standby.
                      Also when it does go into standby are any of the transformers feeding the lamps hotter than the others.
                      • Shane711
                        • 493
                        I have fixed many of these TVs and 50% of the time it is the lamp wires shorting to the other wires or to the frame. Very common and very easy to see if you turn it on in the dark with the back cover off. Sometimes the wires will glow and sometimes you will see sparks. You only need to insulate the wires to fix it.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          It will be interesting to see if this is also the case here.
                          • Shane711
                            • 493
                            Well as I said I was having an issue with no power going to the DVD player. I suspected the secondary power supply part # BA71F0F01026-1. I had another board so I switched it out and now I am getting power to the DVD player and it is currently playing a DVD. My next step is to test the bad board and figure out if I can fix it.
                            • Shane711
                              • 493
                              So I took a look at the Bad board ( BA71F0F01026-1 ) and I found that someone had tried to work on it before and they abused it pretty bad. None of the components were bad but a lot of them were broke loose from the board. There was so much damage I forgot how many spots I had to fix. But the results are that I fixed the broken board and now it is working and playing a DVD.
                              So I repaired the damaged lamp wires and repaired the DVD power board BA71F0F01026-1 and now this TV is working great. I actually have 3 more to work on.
                              • CapLeaker
                                Dell ATX PSU won’t start, but forcing it works fine?
                                by CapLeaker
                                Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                10-28-2024, 06:59 PM
                              • kamiewtype
                                MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
                                by kamiewtype
                                I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
                                The specs are:
                                MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
                                Intel core i9-10900kf
                                2x16gb Corsair Vengeance kit
                                BIOS ver is E7D06IMS.1B0, from 6/12/2023
                                The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
                                I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
                                11-01-2024, 10:52 AM
                              • edugimeno
                                TD Systems K50DLP8F works fine on 1 HDMI, bad on others
                                by edugimeno
                                I have this TV set that I spent a long time fixing it.
                                I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
                                I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
                                I didn't use that TV much at that time. Now that I'm using it,...
                                10-06-2023, 03:00 PM
                              • baglaivlad
                                A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                                by baglaivlad
                                Hello everybody!
                                Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                                After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                                11-20-2024, 08:14 AM
                              • marce002
                                Macbook A1465 works fine Linux but turns off in MacOS
                                by marce002
                                Hello
                                I have this macbook Air 11 inch, was working fine with macos,,, then suddenly turns off by itself after apple logo screen.....it cant boot...
                                Formating and installing does not work because it also turns off.....
                                But: booting linux ubuntu from pendrive and also installing it in ssd works fine!! hours and hours, the macbook runs fine and fast and cool....
                                So she does not like MacOS , loves Linux... can this be related to EFI? I have tried booting macos with shift pressed and allow me to login but even in this safe mode it turns off itself with...
                                02-02-2022, 05:43 PM
