Vizio gv42l No sound No picture
  • jc70nova
    • Feb 2016
    • 7
    • usa
    I have a vizio gv42l fhdtv10a I have no picture or sound. I checked the back light and its not working nor can I see any display with the flash light test.
    The vizio front emblem light turns on but that's it.. When you can turn the tv on you can hear it click and power up but that's it, also you have to unplug it to turn it off want respond to the power button or remote.
    I did some reading and its pointing me to the back light inverter board, but the problem with that is everyone I see that had issues with that board had sound.
    so should I replace the main board?
    Re: Vizio gv42l No sound No picture
    Pictures of the boards?
    Fuses on the main boards are OK?
    • jc70nova
      • Feb 2016
      • 7
      • usa
      I don't have the equipment to check if the fuses are good or not. I trying to get feedback to see what board I need to replace
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Good clear pictures of the rear of the tv showing all of the boards is a good start.
        • jc70nova
          • Feb 2016
          • 7
          • usa
          ok I hope these will work I can get what ever pics are needed.
            You will at least need to have Digital meter to do simple resistance and Voltage testing otherwise you will be doing lots of board swapping.
            • jc70nova
              • Feb 2016
              • 7
              • usa
              ok that's understandable, I was thinking on getting one. IS there a certain one I need to get or just a standard cheap one.
              also once I get one would you be able to walk me threw this
              • Agent24
                I see dead caps
                • Oct 2007
                • 4968
                • New Zealand
                A good quality one is recommended, but if this is a one-off you might as well just get a cheapie. $15-$20 US would be the lowest I'd go. Anything cheaper is probably total garbage and a safety concern.
                You may well find a better (but older) meter on eBay for a low price too.
                As long as it has AC Volts, DC Volts, DC Amps, Resistance, and a Continuity\Diode test mode, it would be suitable. Other extra measurements like AC Amps, Capacitance, are useful but not needed and are not usually found in cheap meters anyway.
                -David VanHorn
                • jc70nova
                  • Feb 2016
                  • 7
                  • usa
                  ok so I ran up to lowes and just grabbed one got it for
                  28.00
                  • jc70nova
                    • Feb 2016
                    • 7
                    • usa
                    ok my friend I went out and got one so could you please give me some help on whats next thanks
                    • kca
                      Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                      by kca
                      Hello all ~
                      I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                      This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                      No picture. No sound.
                      I tested all the voltages coming out of the power supply...
                      10-12-2023, 05:23 PM
                    • ggil44
                      Vizio M65-E0 No Picture, No Sound
                      by ggil44
                      Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                      09-03-2024, 08:30 PM
                    • slimsoul
                      Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                      by slimsoul
                      Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                      I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                      I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                      The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                      03-12-2024, 03:55 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • MOSSEP
                      Monitor Audio RSW12 - Green light, but no sound
                      by MOSSEP
                      Hi
                      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                      I have already tried replacing all of the...
                      01-26-2025, 08:33 AM
